07-16-2012, 08:18 AM | #1 |
engine swap 72 custom camper
Hello, I am new to the forum...I have a 72 GMC 3/4 T custom camper. The original 402 ci engine is Kaput, I have a chance to pick up a good running Olds 455 from a 74 delta 88 c/w trans. Also still have the T400 from my truck. Can someone help to say if the 455 will bolt in where the 402 came out? Can the original mounts be used? I know the exhausts wont fit and the accesories will be different and I can deal with that but Im not interested in doing custom frame work Any advice is much appreciated. Thanks
Rick |
07-16-2012, 03:35 PM | #2 |
Re: engine swap 72 custom camper
No. The trans will not bolt to the engine. Buick/Olds/Pontiac/Cadillac is a different transmission pattern as a Chevy. Also the motor will not bolt to factory mounts. 455 Olds is definitely worth something, sell it and buy a 454 crate engine. You will be better off.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
07-16-2012, 05:37 PM | #3 |
i am sure it will fit, but you will have to make a lot of mods. on the motor mounts and trans mount. you would have to use the olds. trans. and the drive shaft may need some mods...then exhaust , and no telling what else ....in the late 70 and 80's. this was a common thing on the chevy 5.7 diesel motors...they were an olds motor to start with and i put several olds gas motors in and took the diesel out...it was a easy swap...but yours would not be a simple swap.....but it would be kool to have on in your pickup if you wanted to spend the time....
07-16-2012, 11:57 PM | #4 |
Thanks Guys. Thats kinda what I figured. I will keep looking around. Cheers
07-17-2012, 02:56 PM | #5 |
I guess if you used the whole front crossmember from a '73-87 and used the Diesel mounts it would work. I have a '79 that had a diesel in it and now has a gas Olds 350.
07-18-2012, 07:53 AM | #6 |
There is an active thread with an Olds powered truck
http://67-72chevytrucks.com/vboard/s...d.php?t=452193 You can see how it fits, but I still wouldn't do it if not already done. You already have a big block truck with all the correct pulleys and brackets and manifolds. If it were me I would buy a crate 454 and put in there.
07-18-2012, 08:22 AM | #7 |
Florida Edition
Welcome aboard from Central FL. There are some 402s and parts for sale on the parts board.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
07-18-2012, 01:04 PM | #8 |
Just a car guy
It would be a lot cheaper, easyier and retain the value of the truck more more if you rebuilt the 402.
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
