Old 07-16-2012, 10:27 AM   #1
N2TRUX
Happy to be here
N2TRUX's Avatar
What did you get done? 07/15/12 edition
I haven't worked on my 77 in months. Maybe in the Fall I will feel like getting back on it.
I rebuilt my pool pump and replaced a motor, then washed all of our drivers.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-16-2012, 10:35 AM   #2
Firebirdjones
Re: What did you get done? 07/15/12 edition
Finished up painting a customer car. Takes priority over my own stuff so when I get a break I take advantage of it.......
Had time in between jobs so I pulled the steering box off my 79 pickup to change the leaking input shaft seal that has been bugging me for months
Spent a few weeks off and on building a 12 bolt rear for my wifes camaro and finally got that installed.
Finished up building both differentials for the 72 blazer with all new suspension parts and got that up the street for a front end alignment.
Dabble a little time between the other cars with small jobs, and changed oil in 4 of them that I've been putting off for a while. Just didn't have the time.
I have more to do but I'm tired
Firebirdjones is offline   Reply With Quote
Old 07-16-2012, 11:46 AM   #3
Keith Seymore
Keith Seymore's Avatar
Hey - I fixed the cruise on Lil Red this weekend -
I was checking the oil and doing underhood inspections on all the rides this weekend and noticed the link from the vacuum diaphram to the throttle body had pulled through the little "loop" where it attaches.
I welded two small washers on either side and then put it all back together - works just like brand new!
I'm always happy when what I think is going to be an electrical problem turns out to have a mechanical fix.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 07-16-2012, 11:47 AM   #4
JRANGER
JRANGER's Avatar
Painted the passenger door/door jamb
JRANGER is offline   Reply With Quote
Old 07-16-2012, 12:37 PM   #5
88Jimmy4x4
88Jimmy4x4's Avatar
well in between Houston rainstorms.....I replaced the fuel pump module in my wifes Chevy HHR....boy was that fun
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 07-16-2012, 01:44 PM   #6
riz
I pulled the exhaust manifolds from my engine as I prepare to pull the motor. I also cleaned the garage and sold a set of bucket seats. I pick up a truck box stand tonight so I can finally get it off of the jack stands and make it able to move around. I have to pull the truck out of the garage and figure where to put it since my wife is throwing a surprise birthday party for her sister in the garage this Friday. I hopeto have the engine pulled by mid August since I have so much else going on. My K5 Blazer is getting closer to getting paint on it too........ I can't wait!
RIZ
riz is offline   Reply With Quote
Old 07-16-2012, 01:51 PM   #7
foamypirate
foamypirate's Avatar
Started prepping the TBI harness I have to go into my 84' C10. Ordered up a fuse block and some relays to wire up the ECM to 12v batt and 12v key power. It's only for a lowly 305, but I still like the reliability of the fuel injection, and I've got the entire setup just sitting here, so why not?
foamypirate is offline   Reply With Quote
Old 07-16-2012, 03:00 PM   #8
king-918
king-918's Avatar
bought more parts for my 86 and trying to figure out if i should take the truck to the frame or not
king-918 is offline   Reply With Quote
Old 07-16-2012, 03:45 PM   #9
xrcr
picked up my transmission and decided it's still too hot to mess with the old girl aka project mutt
xrcr is offline   Reply With Quote
Old 07-16-2012, 04:29 PM   #10
JNJchev77
Registered Cruiser
JNJchev77's Avatar
I installed a 3 inch lift on my Uncle's 06 Tacoma.
Then cut out the center of the cab floor in my 77 to make way for the trans tunnel. It was downright humid this weekend, in the AZ
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 07-16-2012, 04:35 PM   #11
ratrod67
ratrod67's Avatar
Buffed some paint.
ratrod67 is offline   Reply With Quote
Old 07-16-2012, 06:57 PM   #12
cochino12
It followed me home?
cochino12's Avatar
Got some tires installed along with some new shocks and finally got some miles on the truck.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 07-16-2012, 09:10 PM   #13
jitteryguy
GoatLube Experss
jitteryguy's Avatar
enjoy'd be'n at home , pick'd up a 30ton shop press and clean'd up the yard.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
