Old 07-16-2012, 02:42 PM   #1
burb1085
burb1085's Avatar
A- arm shafts
Would it be possible to use the 3/4 ton upper and lower arm shafts on a 1/2 ton truck? Or would the shafts be to thick to use. Also was wondering if so do the 3/4 ton shaft seal have to be machine pressed in like the bushings do on half tons?
burb1085 is offline   Reply With Quote
Old 07-16-2012, 02:56 PM   #2
tinydb84
tinydb84's Avatar
Re: A- arm shafts
The 3/4 ton shafts use an all steel bushing set up. They wouldnt work with the 1/2 ton arms.
