Old 07-16-2012, 04:42 PM   #1
jlmerie
jlmerie's Avatar
Woodgrain dash bezel
I was out at the junk yard today and found a very nice woodgrain dash bezel from a 1989 Suburban. I thought this would work for the 1981-1987 trucks. After getting home with it, I don't think it will work. Does this style bezel only fit the 88-91 trucks? Thanks
James
jlmerie is offline   Reply With Quote
Old 07-16-2012, 04:51 PM   #2
CaliDude76
All About the BOWTIE
CaliDude76's Avatar
Re: Woodgrain dash bezel
it looks like it would fit, is it the radio opening that doesn't jive?
Just an idea for you, if you want the wood look, try shelf paper, it's sounds cheesy, but it turned out surprisingly clean for me..
CaliDude76
"... Being "SQUARE".. is where it's at...."
Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..."
Be exceedingly blessed today, my friends!...
CaliDude76 is offline   Reply With Quote
Old 07-16-2012, 05:04 PM   #3
Jonboy
Slots go on anything!
The radio opening is 89-91 only. You could use it on 84-up, especially if you were to put in a CD player and black out the dash around it.
1974 Jimmy- 5.3/4L80e/NP241
Old 07-16-2012, 05:12 PM   #4
75chev4x4
75chev4x4's Avatar
I think I have that same woodgrain bezel for an 81-83 that I bought thinking it would fit in my 75. I can look if you want and send you a pic.
75chev4x4 is offline   Reply With Quote
Old 07-16-2012, 05:12 PM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
You can buy wood grain vinyl thats the same that they used on the trucks
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 07-16-2012, 05:19 PM   #6
75chev4x4
75chev4x4's Avatar
Do you know who sells them?
Old 07-16-2012, 05:45 PM   #7
jlmerie
jlmerie's Avatar
Yes, I think it is the radio opening that will not work. It is not just that I like any woodgrain, but I like the woodgrain used on these trucks. So far as I can tell it is very different from all the 87 and earlier woodgrain. It is bright and has a true burl look to it. I have tried the "shelf paper" thing in the past. I could never find anything that was the exact right match and it was only a matter of time before it started to peel. I am adding a picture of the dash in my 1978 GMC. I don't know who added the woodgrain but you can see a lot of the corners have started to peel away.
James
Old 07-16-2012, 05:48 PM   #8
JCampbell
Is that a 1.5 DIN opening?
JCampbell is offline   Reply With Quote
Old 07-16-2012, 05:58 PM   #9
jlmerie
jlmerie's Avatar
I don't mean to sound stupid, but DIN?
James
Old 07-16-2012, 10:45 PM   #10
Greenlee
Greenlee's Avatar
I got one out of a 89' Suburban also and it came with an adapter to mount a normal size aftermarket DIN stereo. It will work in our trucks with this adapter. I plan to use it in my truck with the adapter. I'm not sure if someone made this or it was sold in the aftermarket.
Greenlee is offline   Reply With Quote
Old 07-17-2012, 04:20 PM   #11
motornut
78K & 79C Jimmys
motornut's Avatar
i have a 89 pad on a 78 truck with 78 bezel
works no gaps
89 bezel the wipers are in the coloum ,before mid 80s it's in the bezel
when the wipers move the hole in the bezel moved for the headlight too
89 bezel with 78 pad left a weird gap along the top of bezel
it's the same as my 89 btw
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 07-17-2012, 05:15 PM   #12
TheApocalyptican
TheApocalyptican's Avatar
The one you got is indeed for 89-91. It is a 1.5 din opening. Motornut covered the rest of the info.
Din is used to describe stereo opening sizes. Most aftermarket stereos are 1 din. The ones that have like a 6" or 7" screen for nav or other uses are 2 din, or the size of two of the regular ones stacked on top of each other. 1.5 din is half bigger than a regular stereo.
1 din:
1.5 din:
2 din:
1995 Suburban K2500 454.....off road & towing
1999 Astro, work van
2006 Silverado 2wd 5.3 w/4.5" lift and 33s
TheApocalyptican is offline   Reply With Quote
Old 07-17-2012, 05:32 PM   #13
RandyP
Getting Old; Going Broke
RandyP's Avatar
And the radios that would have been in there pictured. Very easy to make them fit, especially if the dash has already been butchered for an aftermarket radio.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
