07-16-2012, 06:22 PM | #1 |
SKINNY TIRES RULE!
First Gen Sliding windows - CL Portland
http://portland.craigslist.org/clc/pts/3143165616.html
You don't see these for sale very often. Odd that they open like a PU rear window, but still would be nice to have. NOT MINE, just found on CL and thought I'd share.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
07-16-2012, 07:45 PM | #2 |
SWB 4x4 Collector
Re: First Gen Sliding windows - CL Portland
Been looking for a set, but I heard they take a special rubber weatherstrip which is missing. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
07-16-2012, 09:51 PM | #3 |
SKINNY TIRES RULE!
I doubt you'll find any with the rubber weatherstrip. I'm sure if you pickup a catalog from a weatherstrip company, you'll be able to find some stock that will work.
07-16-2012, 10:51 PM | #4 |
Member #1049
The rubber on the set that I used to have looked to be just a stock double wall gasket, (unfortunately I cut it and tossed it upon removal)
I think they used a special gasket when going into a single wall top due the flange being thicker than stock single wall glass. |
07-17-2012, 12:56 AM | #5 |
I saw this one at the Sacramento swap meet last year. NFS.
07-17-2012, 08:23 AM | #6 |
Do you think they used different seals on the sliders as aposed to glass seals? The reason I ask is side glass is pretty thick. I just seems to me that if the manufacture is making a special slider for these tops that they would or could use the same seals. Also I have read in other post that some say that the seals for a double wall and single wall are different, I've had both and interchanged with no problem, the flange where the seal sits on top was the same on my double and single.
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
07-17-2012, 11:25 AM | #7 |
SKINNY TIRES RULE!
If you look at the pictures, it looks like the aluminum frame is pretty narrow where it goes into the weatherstripping. I would suspect that the aftermarket manufacturer used an off-the-shelf weatherstripping rather than having something manufactured specifically for their windows. That would make me think they used the factory seals.
07-17-2012, 04:07 PM | #8 |
I'm with ya!
07-17-2012, 09:25 PM | #9 |
I tried to respond to the ad, but it said it was no longer active. Anyone else try, or have a way to contact the guy?
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
07-18-2012, 09:14 AM | #10 |
Boosted Member
I contacted him yesterday...said they were sale pending to a local guy. I told him that I'd take them if that deal fell thru
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
07-18-2012, 04:06 PM | #11 |
Were these original Gm installed?
1972 Chevrolet Blazer 4x4 (Almost done stay tuned) 1970 Chevrolet Pickup Longhorn CST/20 (SOLD) |
07-18-2012, 04:29 PM | #12 |
SKINNY TIRES RULE!
Aftermarket. A dealership may have sold/installed them but not factory.
