Old 07-16-2012, 10:36 PM   #1
superwade57
lt1 t56 swap starter wont fit?
i havent seen anything on this here after search upon search so i need info probably from someone whos done the swap. my stock starter wont fit in the t56 bell housing, i have 3 sbc starters laying around and all are the same and none fit. ive heard/ read that some manual tranny gm cars had a smaller starter can anyone confirm or deny this? i dont need an expensive aftermarket gear reduction, i just need a stock gm starter that will bolt to my old *****010 gm 350. im using centerforce adapter flywheel 700107. says its 153 tooth.
superwade57 is offline   Reply With Quote
Old 07-23-2012, 11:02 AM   #2
superwade57
Re: lt1 t56 swap starter wont fit?
Ttt
Old 07-23-2012, 11:21 AM   #3
Jonboy
Slots go on anything!
Wouldn't the LT1 starter work?
1974 Jimmy- 5.3/4L80e/NP241
Old 07-23-2012, 11:30 AM   #4
superwade57
I'm Not sure I sold the one I had...like an idiot so I wanted.to know before I bought one my parts store has to order it since its not on the shelf. Gonna check an OReilly tonight in the next town over s
to see if they have one on the.shelf to try
Old 07-25-2012, 10:56 PM   #5
superwade57
ok finally yes the stock starter fits providing your old block is drilled and tapped with the extra starter holes, which mine is YAHOO! problem solved plus its much smaller and leaves plent of room for headers
