Old 07-16-2012, 10:43 PM   #1
ole dollor
ole dollor's Avatar
pic's of new seat and column
here is some pic's of the seat and steering column ....i hope....
ole dollor is offline   Reply With Quote
Old 07-16-2012, 10:50 PM   #2
brianthelion02
Overdrive club
brianthelion02's Avatar
Re: pic's of new seat and column
Looks great!!!
1971 c-10
1951 3100 chevy
1970 chevy c-30 Sold!
brianthelion02 is offline   Reply With Quote
Old 07-17-2012, 07:50 AM   #3
Did you get what you expected out of that? How do you like it?
Old 07-17-2012, 11:24 AM   #4
ole dollor
ole dollor's Avatar
special-k :yes the column drop further into the dash gives a lot more belly room, and i think a more comfortable arm position while driving....and the back of the seat can have a little more padding ....i tried to post pic's on the other tread i started and was not able to....i used three different seats to make one...it was quite a chore...but i think it turned out ok....
Old 07-17-2012, 04:21 PM   #5
midniteblues
midniteblues's Avatar
does ole dollar have power steering?
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 07-17-2012, 06:48 PM   #6
ole dollor
ole dollor's Avatar
midniteblues : yes ole dollar has p/s now i had to put it on, its a 292 and hard to find brackets....
Old 07-17-2012, 06:57 PM   #7
Malamute
Malamute's Avatar
Looks good.
Malamute is offline   Reply With Quote
Old 07-17-2012, 09:12 PM   #8
midniteblues
I cant even imagine all the 6 cly stuff our crew tossed back in the day nobody wanted six parts! If only we could see into the future!
any way I was curious cause I would think that without ps the shorter colum wouldnt give as much leverage to crank on the wheel. with the ps I'm sure it doesnt matter.
Old 07-17-2012, 09:13 PM   #9
midniteblues
Oh btw, ole dollar is looking good these days. nice work
Old 07-17-2012, 09:54 PM   #10
ole dollor
ole dollor's Avatar
thank you all for the kind words....its kinda hard building with no budget ....its going to be slow process but one of these days i will have a good daily driver...
Old 07-17-2012, 10:39 PM   #11
CG
BlahBlahBlah
Looks comfy
Old 07-18-2012, 01:15 PM   #12
ole dollor
ole dollor's Avatar
on ole dollar the old steering gear had been run without any oil for no telling how long..i was having trouble driving it, i filled it up with amsoil gear lube and jb 80 spray to make the gears slicker....it did help ... it drove a little better. until i took the gear box off to put the power steering box on , i did not know that it would only turn a little left and right without binding up...you could not turn it all the way any direction with out a pipe wrench...i am not sure if all our year models manual steering boxes were hard to turn when working right....my son has a 1963 c-10 that drives easy, even at slow speeds you can steer it with the palm of one hand....maybe the 60's trucks just steered easier , anyone else have a real hard steering truck, might want to check their gear box.
Old 07-18-2012, 08:13 PM   #13
Boog
laying low
Boog's Avatar
It could be someone has tightened the adjustment screw to much causing the sector to bind up that way. Power is better anyway. Looks good. What are the seat and column out of?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 07-18-2012, 10:10 PM   #14
ole dollor
ole dollor's Avatar
boog : the steering column is the original one ...i just moved it into the dash about 2 1/2 " ....now the seat was a different story, a friend gave me a seat he thought was from and international pickup with brand new seat covers. he had had it a while and was not sure, so i took the original seat that came out of ole dollar and a seat out of a 1985 gmc pickup and the I H seat and took them all apart. i took the bottom of the I H seat and put on top of my old seat frame. that made the bottom, then i took the foam out of the 85 gmc seat back and put it on my seat back. i put the 85 gmc seat cover back on and then took the new seat cover and put it on the part i had put together ....that made the seat back....put it back in ole dollar and bolted it all together, i was not easy but i think it looks good, now i am going to have to make gray and gold match together, with my maroon shoulder belts. next paint the door panels and arm rest to match the inside....any ideas would be welcome on what colors would look ok, gray seats ,brown carpet, black steering wheel, gold cab. what color goes with these....
Old 07-18-2012, 10:25 PM   #15
Boog
laying low
Boog's Avatar
Seat fitment and padding looks good. As far as the cab colors are concerned you can do a lot with rattle cans in there.
Boog
primer is finer
Old 07-18-2012, 11:27 PM   #16
70cst
70cst's Avatar
Looks very drive-able.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
