Old 07-17-2012, 01:42 AM   #1
barn9
Half a bubble off!
barn9's Avatar
Question Broken AC line.
Had a hinge pin going bad and it rubbed a hole in the line shown in the photos. Found a used hinge to replace it, and wouldn't you know, when I opened the hood the old hinge caught the line and broke it right behind the connection nut. The guy that had the hinge also brought an old assembly, but the line was a different size, so my idea of possibly using a union and making the fix went out the window.
My question is, have any of you ever tried a repair on one of these aluminum lines? I don't really want to tear into the firewall and try and replace the whole thing even if I can find one, would just like to repair or patch this line if possible. I'm gettin' too old for major mechanical projects, the ol' body boycots this sort of activity. Any ideas will be appreciated. Even if I have to JB weld the darned thing, LOL!
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 07-17-2012, 03:03 PM   #2
Gumby
Gumby's Avatar
Re: Broken AC line.
FM104 bumper stickers n ducttape
Gumby is offline   Reply With Quote
Old 07-17-2012, 03:26 PM   #3
Lee H
Lee H's Avatar
Re: Broken AC line.
Any A/C shop can repair that line.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is online now   Reply With Quote
Old 07-17-2012, 06:46 PM   #4
cableguy0
Re: Broken AC line.
You can give it a shot with duct tape and bubble gum but you need a new line. A/C runs too much pressure to mess around with bad connections or patches. If that line has no rubber in it just grab one from the junkyard.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 07-19-2012, 06:59 PM   #5
barn9
Half a bubble off!
barn9's Avatar
Re: Broken AC line.
I live in a small town, not sure I would trust any of the AC repairmen around here being in the vicinity of my truck while having any kind of torch in their hand. Same problem with finding parts, the idiots at the local O'Reilly's are incapable of even understanding the issue, let alone finding the correct parts.
I did find this (Devcon FasMetal 10 hvac repair) from doing some online research, thinking of ordering a tube and trying to fix it this way.
Just call me LB.
Old 07-21-2012, 09:45 PM   #6
terry b
terry b's Avatar
Re: Broken AC line.
What is the o.d of the line? It look's like 1/4 inch. If that is true then 1/4 inch aluminum pilot tubing for a furnace is the same thing. It look's like it is a vacuume line not a refrigerant line. Is this true? If so then get a 1/4 inch coupling and some tube from a heating supply house or service man. I don't know about reusing the nut.
terry b is offline   Reply With Quote
Old 07-21-2012, 11:01 PM   #7
100%Chevy
Re: Broken AC line.
It's a refridgerant line @ about 150 psi and is welded to the evaporator inside the housing.
Just find another good evaporator.
Take the engine side of the case off and replace the evaporator core.
Mike./
100%Chevy is offline   Reply With Quote
Old 07-21-2012, 11:34 PM   #8
oldspowered67C10
Re: Broken AC line.
A new evaporator is the best plan but Ive had those kinds of thing repaired before. I remember one time we had a Ford Excursion with a hole in a line under the body that goes to thew rear evaporator. Replacing it would have been a pain in the ass w/o removing the body from the frame so we had a local welding shop repair it for us, worked fine. Truthfully though, evaporators aren't too expensive and aren't too terribly hard to replace so Id just get a new or good used one and replace it.
oldspowered67C10 is offline   Reply With Quote
Old 07-22-2012, 12:20 AM   #9
leddzepp
Moderator
leddzepp's Avatar
Re: Broken AC line.
A new evaporator is $250. I would see about a repair first.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 07-22-2012, 02:53 AM   #10
SS Tim
SS Tim's Avatar
Re: Broken AC line.
Have to agree with leddzepp. There seems to be enough line there to splice a line section into. Maybe someone with a dead evaporator would be willing to donate a section.
SS Tim is offline   Reply With Quote
Old 07-22-2012, 10:49 AM   #11
barn9
Half a bubble off!
barn9's Avatar
Re: Broken AC line.
Thanks for the input everyone. And where did this post get moved to?
Just call me LB.
Old 07-22-2012, 04:03 PM   #12
terry b
terry b's Avatar
Re: Broken AC line.
If he is looking at a repair of the line then how? Would you swedge the end of the new line so the old line slip's inside and have it welded? Or would you try a flare fitting? I have tried to gas weld aluminum a few time's. I can get it to hold together but never to hold pressure.
Old 07-23-2012, 03:14 PM   #13
terry b
terry b's Avatar
Re: Broken AC line.
ttt
