07-17-2012, 08:52 AM | #1 |
Hidden receivers which one?
Want to put one of these in my 72 LWB fleetside. I have a Boyds tank to mount there as well. Is there one I should use vs another that will fit well with the rear mounted tank?
Thanks |
07-19-2012, 01:18 PM | #2 |
Restoration Virgin!
Re: Hidden receivers which one?
I believe Early Classics Enterprises (ECE) has one, but I'm sure there maybe others as well....
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
07-20-2012, 10:06 PM | #3 |
I think you'll find that the ECE hitch and tank mounting flanges will want to occupy some of the same space on the frame rail. I don't that for a fact though. If so, I guess you could mount the tank below the hitch and add spacers on the front of tank flange, but I don't think it's a "clean" install.
I used a CPP hitch - it bolts on through the side of the frame rail and won't interfere with the tank. It isn't cheap though. Last edited by bubba353z; 07-20-2012 at 10:20 PM. |
