I6 motor mount pics?
well first off i need an idea how to tell if this new motor is a 194/230 or a 250 def. not a 292 is there a way to tell by dipstick location or some other give away?
Second it came from a 71 nova so i need the steel part of the mount that bolts to the motor from a truck any one have a line on them?
96 s10 static drop smooth and blue 99 silverado nothing stock layed out on 24s 65 c10 bagged patina driver http://www.myrideisme.com/Garage/az480 half-assed build thread http://67-72chevytrucks.com/vboard/s...=1#post5206828 |
Re: I6 motor mount pics?
Chevy quite using the 230 in 1966 when the 250 replaced it. Odds are its a 250. You will need the numbers on the pass side of the engine by the distributor to tell for sure.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
