Old 07-17-2012, 03:22 PM   #1
grayharville
^^who I am^^ what I say>
grayharville's Avatar
cummins conversion quick question
Hey guys im putting a 91 cummins with a getrag in my 87 crew.
I got everything figured out except the clutch hydraulics, anyone got any ideas?
70 chevy LWB 350/TH350 Barn find (AKA the 70)
http://www.67-72chevytrucks.com/vboa...d.php?t=406364
East Tx Squares
grayharville is offline   Reply With Quote
Old 07-17-2012, 04:01 PM   #2
86c20
86c20's Avatar
Re: cummins conversion quick question
if its just the line any hyro shop or napa should be able to make one
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 07-17-2012, 04:13 PM   #3
grayharville
Apparently I have to use a ford master cylinder with a jeep slave, not sure. Was wondering if anyone has any insight
East Tx Squares
Old 07-17-2012, 04:25 PM   #4
86c20
86c20's Avatar
go over to 4bt swaps there are a lot of guys there that will now
Old 07-17-2012, 09:57 PM   #5
odee
what tranny are you putting behind the cummins? I have just finally started to drive my swap some here latley. I found info over on the 4bt swap site. I used a ford truck master made a wedge for the firewall then the slave was for the dodge tranny that my 6bt came with. Mated the slave and master with a explorer clutch hose. Hope this helps
odee is offline   Reply With Quote
Old 07-17-2012, 10:16 PM   #6
grayharville
Im running the getrag 360. Can you elaborate on the wedge and clutch hose? Pics are good too
East Tx Squares
Old 07-24-2012, 07:59 PM   #7
Lobie
When I put my cummins in my 79 Cherokee with the g360 I used a mid 80's ford 350 master cylinder and the slave for the getrag. I bought some clutch hydraulic fittings and braded line from summit. Works great but now it's going in my suburban with an auto. Check on my website in my sig and go to vehicles then "the jeep". There may be some pics towards the end.
87 Suburban R20 (6bt Cummins)
79 Cherokee Chief (454 from Suburban)
- both in progress
http://lobie4x4.com
Lobie is offline   Reply With Quote
