07-17-2012, 03:27 PM | #1 |
Np205 10 spline to 4l80e
Ive read just about every forum on the face of the web and now am more confused than when I began this endless quest. I have a 10 spline np205 I'm rebuilding right now. I am going to purchase a lq9 and 4l80e in the near future.
With that being said, who has actually mated a 10 spline figure 8 np205 to a 4l80e? Which 4l80e did you use? Which adapting method did you use? I have many more questions, so if there is some one out there with this knowledge, can I pick your brain? Thanks Posted via Mobile Device
69 k10 - In pieces |
07-17-2012, 09:06 PM | #2 | |
Re: Np205 10 spline to 4l80e
07-17-2012, 10:31 PM | #3 |
Get a 205 from before 1984 from behind a th400. Its a 32 spline 205. Use the 4x4 4l80. 4l80/th400 indexing ring adapter/spacer thing. Then a figure 8 th400/205 adapter, then the figure 8 32 spline 205.
Call off-road design. The 4l80 has a different bore size than the 400. Posted via Mobile Device |
07-18-2012, 08:10 AM | #4 |
So basically my 10 spline is hopeless when it comes to the 4l80e?
07-18-2012, 10:36 AM | #5 |
07-25-2012, 08:12 AM | #6 |
I had a slip joint newer 205 with th350 input and a 10 spline 205. I swapped inputs and now have a u joint th350 205. The case can be machined for the larger th400 bearing and 400 input would slip right in. Kinda hard to find th400 units.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
07-25-2012, 08:22 AM | #7 |
I called off road design and they helped me out a bunch, it seems that the most straight forward way for my situation is to machine the 205 input hole out to fit a long 32 spine female shaft in there, and buy the modified th400 adapter they sell. I can get a rebuild kit, the new input spline with all the bearings, and the adapter that mates to a 4x4 4l80e all for about $600. I guess that's not too bad, I'm going go that route unless someone knows a cheaper way to go, but the ord guys know there stuff and helped me a bunch.
