Old 07-17-2012, 05:14 PM   #1
MikeS.
MikeS.'s Avatar
Burb vs truck
I need to replace the metal on the floor of my 63burb where your feet go up near the firewall on both sides.
Here is the right side
This is the worst of it. Will patch panels from a Truck be the same?
How about this area of the floor? It is on the right side between the front and rear seat. Will a piece of truck floor work?
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 07-17-2012, 08:11 PM   #2
rossboss
rossboss's Avatar
Re: Burb vs truck
The pieces from the seat foward will fit no problem, I replaced both sides on my suburban. However from the seat back is a differennt story. I didn't have to replace mine but the floor does change from the seat back. Might have to do some of your own fab work.
rossboss is offline   Reply With Quote
Old 07-18-2012, 12:23 AM   #3
Captainfab
60-66 Nut
Re: Burb vs truck
I agree with rossboss.
The forward floor area is identicle to the trucks. The passenger side outer floor and inner rocker is different than on a truck, and of course from the B-pilar back is specific to the Suburban. Also the rear 'cab mounts' are different on the Suburbans.
Old 07-18-2012, 12:26 AM   #4
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Burb vs truck
the passenger floor has a "step" in it for the rear seat passengers to enter. so this is very different from the truck.
however I did see a guy on this board fix his up with the truck stuff, and just delete the step, his was very rusty.
I will try to find the thread and pics for ya'
as stated the front floor pans and foot wells and outer rockers will work with truck patch panels. you will probably just have to fabricate the step portion with some sheet metal.
capt. and I posting the same thing at almost the same time..
Old 07-18-2012, 03:21 AM   #5
MikeS.
MikeS.'s Avatar
Re: Burb vs truck
Thanks guys. Jon, if you can find that link that would be great.
Past Master
