I was washing my 85 K5 and noticed while I was doing the wheels that two of the studs were snapped off. It's 6 lug and the two broken ones were directly across from each other. I have never seen this before and can not figure out what caused it. Has anyone had this happen or know why it would happen? I am stumped.
ROCKET POWER!
Reason: Impact wrench and serious overtorque.
[edit] Or did you mean they were fine the last time you looked but had just snapped? Most of the time it's because tire dealers do it the quickest way.
What did i do last nite? I had a wonderful time, That's what they tell me What did i do last nite? 1979 C-10 shortfleet: Olds 350, Th400, 12 bolt Current project: 1969 Olds 455 W-30, needing a rebuild Last edited by RockHQ; 05-20-2003 at 03:42 PM. |
They were fine the last time I looked. I put the rims on myself with a torgue wrench to the specified poundage. That is why I can't understand what happened.
Maybe they were damaged by previous over-torquing.
That's very possible. It just struck me odd that two of them would break off. I did have a problem with my drive shaft that was created from a lift that I installed. It caused a shimmy in the shaft so much that it leaked. I thought that may have thrown everything off in the rear end. I don't know.
