Old 07-18-2012, 05:58 PM   #1
8door
Not too old to learn
?????? All the holes in firewall ???????????
Took picture before tear down, right ? yes.
Put those pictures on computer ? yes.
That was seven years ago.............same computer now ?
well er ah ......nope. It died can't retrieve sh.......stuff
All nuts and bolts and parts were labeled and bagged, but no notes on what wires, cables, pieces got through or attach to each hole in the firewall.
Seems old memory faded like the computer did.
I figured out some more obvious holes, like the steering shaft, master rod hole,
the two square holes for main wire connectors next to the steering shaft.
But that's where the brain freeze won't thaw
Any one got pictures or label or reference to a diagram ?
1968 C10 a way to long restoration.
8door is offline   Reply With Quote
Old 07-18-2012, 08:09 PM   #2
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
Re: ?????? All the holes in firewall ???????????
Hope this helps. It's from the forum. I'm not sure who gets the credit.
"Instructions are just another mans opinion"
Become a Supporting Member
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
Old 07-19-2012, 12:46 PM   #3
gcburdic
Restoration Virgin!
gcburdic's Avatar
The above is a 69-72 cab....the 68 cab ebrake exits under the fuse block
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 07-19-2012, 01:16 PM   #4
8door
Thanks for the info.
One more hole not identified on mine. Under the steering column
is a square hole . Can't figure what goes through there ?
Old 07-19-2012, 04:27 PM   #5
67c10rustbuket
67c10rustbuket's Avatar
This hole ? (finger) That is the Park brake cable on '67-'68 models. Just removed mine last week
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 07-20-2012, 12:57 AM   #6
8door
That's the one. After mounting the park brake handle I saw how it lined
with the square hole then looked in my pile of parts and recognized the brake cable, even found the square grommet.
Thanks rustbuket.
Old 07-20-2012, 09:54 AM   #7
gcburdic
Restoration Virgin!
gcburdic's Avatar
oops...I meant under the steering column hole! looks like you figured it out!
Geoff with a G
Old 06-11-2017, 08:39 AM   #8
gmc 2500 4x4
nice
gmc 2500 4x4 is offline   Reply With Quote
