Old 07-18-2012, 06:16 PM   #1
Hazieview
Building Dreams out of Dimes!
When i turn my blinker on all my gauge needles jump???
I am in the process of rewiring my truck and obviously did something wrong. When i turn my left blinker on the gauge needles jump. What gives?
1981 Chevy short/wide.
SB400 350th
Hazieview is offline   Reply With Quote
Old 07-18-2012, 07:00 PM   #2
spencer_41188
spencer_41188's Avatar
Re: When i turn my blinker on all my gauge needles jump???
ive had a simular problem and there is a ground that is on your e brake i do beleave that is the ground for the dash eather clean it or move it
i moved mine to the 6 prongs in the firewall seeing the e brake bults where rusty and didnt wana break it
88 gmc v3500 bonus cab classy chassy conversion, 454, nv4500, np205, dana 60 front with spool, 14 bolt ff cac rear with locker.
spencer_41188 is offline   Reply With Quote
Old 07-18-2012, 07:10 PM   #3
71swb4x4
71swb4x4's Avatar
My first thought, even before reading Spencer's reply, was that you have a ground issue.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-18-2012, 08:03 PM   #4
Hazieview
The only time it does this is when the headlight switch is on. Nothing works unless i have the headlights switch on.
Heck the dadgum key won't even start the truck.
SB400 350th
Old 07-18-2012, 08:18 PM   #5
hatzie
Moderator
hatzie's Avatar
The instrument cluster grounds are not good. All 3 grounds are spliced to a single wire in the harness behind the cluster.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-19-2012, 11:21 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
here
make sure the circut board is straight too
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 07-19-2012, 03:16 PM   #7
Hazieview
I made sure the ground is good, the ignition power is good but I still have the same issue. Will not start with key, gauges only flash when light switch is pulled out to the on position and left blinker is on. I just don't get it.
Why would the combination of the left blinker and headlights cause this?
I did turn my engine over with a pushbutton starter but still no responce on any of my gauges. Blinker dash lights won't work.
SB400 350th
Old 07-19-2012, 08:26 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
wondering if the cluster is the right one or wired right
do you know?
wires move with the different styles
John
Old 07-20-2012, 04:40 AM   #9
Hazieview
Well I'm using all autometer gauges and a painless performance harness. I think the gauges are wired right.
What is throwing me is that the key won't start the truck and the whole blinker thing. The high beam indicator works. The headlights work when I turn on the lights. The headlights will go to high beam and low beam.
SB400 350th
Old 07-20-2012, 04:55 AM   #10
WarBeard
WarBeard's Avatar
This is a long shot.......I drive a School bus and one day During my pre-trip inspection. I turned on my left turn signal and all the gauge lights started to blink in time with the blinker. What it was, The left rear blinker bulb had shorted out in a way that it was sending power thru the ground wire. It's hard to explain.......Check your light bulbs.
1978 C10 Silverado Big 10 350/350.. play toy
1990 V1500 Suburban 350/700r4..Daily driver
1987 K10 Silverado 383/400.. Wife's rig WRECKED!
1989 V2500 Suburban 350/400.. SOLD!
1974 C10 Custom10 LWB 350/350.. SOLD!
1974 C10 Custom10 SWB 350/400.. SOLD!
1999 Silverado Z71 LS1.. Wife's rig WRECKED!
On the hunt for a new project.......
I'm a Chevy guy.....I'm just not a "NEW" Chevy guy.
WarBeard is offline   Reply With Quote
Old 07-20-2012, 10:13 AM   #11
Hazieview
An old timer at work said that my gauges could be getting power off of the headlights switch instead of the ignition which would make since. The only time I get power is when the headlights are on.
SB400 350th
Old 07-20-2012, 06:49 PM   #12
71swb4x4
71swb4x4's Avatar
That tells you that your ground is bad. You need the ground to complete the circuit. Without a GOOD ground you only have half so it's trying to pull power from the headlight circuit.
To test that theory hook up a seperate ground with alligator clips and see if it helps. It won't take much time.
Also check your grounds from the battery to the block, block to the cab, etc.
