07-18-2012, 09:13 PM | #1 |
c10 leaf spring bushing size?
I couldn't find an answer with my search...what size are the leaf spring bushings (front & shackle) for a 72' c10? Had to torch the bolts out and I want to replace with polyurethane.
08-04-2012, 01:28 PM | #2 |
Re: c10 leaf spring bushing size?
The old bushings in the spring measure 1.25". The spring width is 2.25". All that I can find are 1.5" O.D. bushings. I did find a napa part # 274-1185 but these are rubber and I want poly. Anyone with the same issue as me? This is holding me up. Thanks in advance.
08-04-2012, 02:33 PM | #3 |
i'd chuck up 1.5 bushings in my drill press and grind and sand till they wer 1.25 tthat is an old school way of solvin a problem
08-11-2012, 09:31 PM | #4 |
I ended up going with a Moog part # SB319. These fit. Hope this helps someone.
08-12-2012, 01:35 AM | #5 |
Fabricate till you "puke"
That would be the way I would have done it....just because some GD engineer told me I couldnt crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
08-12-2012, 12:35 PM | #6 |
I went around and around trying to find an answer to this question a while back and never found a solution.
