Old 07-18-2012, 09:14 PM   #1
MikeS.
MikeS.'s Avatar
I need some parts help
I put the front axle from an 87 4x4 Suburban on my 63 Burb. The 87 axle didn't have a pittman arm. I'm having trouble getting the proper pittman arm. Looks like the part houses are sending me a 2x4 arm, 1 end has a tie rod.
What I need is the arm that has 2 open holes, 1 on each arm.
Does anyone here know the part number I need and or where to order it from?
Thanks!
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 07-18-2012, 09:54 PM   #2
Re: I need some parts help
Got pictures? What is your steering box from? A 4wd pitman arm uses a bolt through a key way on the shaft and a 2wd uses a nut on the end of the shaft.
Old 07-19-2012, 04:50 AM   #3
MikeS.
MikeS.'s Avatar
A rebuilt ps box from an 87 v10 4x4 Burb.
Past Master
Old 07-19-2012, 06:40 PM   #4
Mike C
Mike C's Avatar
I replaced the one on my '72 Jimmy with one from a '91 Suburban when I did it years ago, the earlier trucks were discontinued. The 4x4 arm is not considered to be a wear item. You may have to get a used one.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Mike C is online now   Reply With Quote
Old 07-19-2012, 10:41 PM   #5
MikeS.
MikeS.'s Avatar
Found a used 1 on e-bay for 26 with shipping. I bought it. Went by the local Chevy dealer, a new 1 is $195.00! Parts guy there has 1 he'll sell me for 20. I'll get the 1 off of e-bay and see how it is.
Past Master
Old 07-23-2012, 11:59 PM   #6
MikeS.
MikeS.'s Avatar
Past Master
Old 07-24-2012, 12:00 AM   #7
MikeS.
MikeS.'s Avatar
Got the arm from eBay works fine not bad for about 27 bucks total.
Past Master
