Old 07-18-2012, 11:19 PM   #1
GM-power
GM-power's Avatar
Question speaker question
In my 79 I have one kick board speaker. I have a set of 2 way speakers and am wondering how the heck to install them. I don't know much about the wiring on the truck. Help is much appreciated!
GM-power is offline   Reply With Quote
Old 07-19-2012, 09:25 AM   #2
ymerej71
ymerej71's Avatar
Re: speaker question
Wiring these speakers into your truck is very simple. The fact that they are 2-way speakers doesn't really have much to do with the wiring itself. A "2-Way", also known as a Coaxial speaker simply means that you basically have a small woofer and a mid-range / tweeter all built into one speaker cage unit.
Basically all that is needed to wire in your speakers is to tie them into the correct speaker output channels on the back of your truck's head-unit / radio. Any radio should have, at a minimum, two sets of speaker outputs... (1) left & (1) right. These easiest way to determine which wires these are is to trace the existing wire attached to your speaker to the back of your radio. The wires to the speakers are a simple + to + and - to - connection at both the radio and the speaker terminals. The most difficult part of the whole project is getting to the backside of your radio to gain access to the speaker outputs.
Hope this helps somewhat... good luck on the install! The coaxial speakers will be a nice sound improvement!
ymerej71 is offline   Reply With Quote
Old 07-19-2012, 10:11 AM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
is it stock?
AM mono one speaker?
is there an ohms rating?
I think lower then stock ohms over heats the radio amp
may damage it
info for stock wires
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 07-19-2012, 10:19 AM   #4
ymerej71
ymerej71's Avatar
Originally Posted by motornut View Post
is it stock?
may damage it
VERY GOOD INFO! Sorry, I get ahead of myself and forget we're talking about 30+ year old vehicles here. Haha..
Old 07-19-2012, 07:30 PM   #5
GM-power
GM-power's Avatar
Its a sanyo am/fm with a cassette deck. It is a double knob
Old 07-19-2012, 07:41 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
does each speaker have it's own ground, or - wire
or is there only one black
if only one, then each speaker -, and the power -, all need to go to the body ground
but don't ground the speakers if they have their own -
throw up a pic
John
Old 07-19-2012, 07:57 PM   #7
GM-power
GM-power's Avatar
@motornut I haven't actually started to put them in but was just wondering if was something that I could on a weekend. As for pics I have to figure out how to post them from my phone
Old 07-19-2012, 11:01 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
Don't think you can "phone" pics in yet
Shouldn't be too hard
Be sure to support it from behind
Might bend the knobs or worse
John
Old 07-19-2012, 11:15 PM   #9
GM-power
GM-power's Avatar
Yeah. I am going to try and get to it when I have plenty of time.
