converting 85 chevy to a 5.3
85 Chevy 350 with th350 wanna keep the trans in it have whole 2002 gmc for motor harness what do I need for swap from truck and what do I need to modify first time doin swap here's a few pics of truck
Posted via Mobile Device |
Re: converting 85 chevy to a 5.3
Motor mounts and buy a flexplate or find one from a 4.8,5.3,6.0 with a 4l80e price of cake swap I got one on a 81 shorty
If the engine is drive by wire you need to mount the gas pedal from the new truck or change it over to a throttle cable.If it was me spending that kinda time and money i would use a over drive trans so i get the best gas mileage i can.
I used the factory under hood fuse block on my swap. You will only have 3 wires to hookup to make it run.
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
I did the swap and used the 4l60e. I have 20's on the back and still get 17mpg. I love it. Stays below 200 degrees running temp to.
those of you that have done this swap including the trans, what did you do for the speedo cable? because isn't the older engine & trans using the cable while the newer one is electronic? I have been considering this swap and using the more up to date 6 speed auto in my 87 short bed with 305 & 700R4.
They sell a converter box i can't think of its name but it has a motor in it to spin the speedo cable so it works.Or the 91 crewcab used a 4l80e wonder if the gauges could be swapped over?
I used the gauges out of a 91 surburban cause the Speedo is electric. It works perfect up to 70 then it gets off by 5 mph.
#9 | |
Do you know who sales the converter? Also has anyone ever done the swap to a 6 speed auto instead of the 4 speed? If so is there any concerns with trans mounts or other issues? Thanks |
Slots go on anything!
PM Shon on the board and get a price from him for a Cable-X. That's what you are looking for.
1974 Jimmy- 5.3/4L80e/NP241 |
http://www.atrol.com/cablex.htm
$279 or $329 plus shipping is what I believe they told me. Posted via Mobile Device
74 C10 LWB 350/T5 Dropped on 20's Soon to be Bagged and Injected 84 C35 Crew Cab Dually. 454/400 Dropped a lot. Instagram: mmmdropp |
Edit: Double post... My bad
