07-19-2012, 01:22 AM | #1 |
Steering issue 1970 GMC 3500
This truck has run about 150k miles and is new to me from original owner. On the 500+ mile run home on good roads, the power steering performance was pretty solid with very little "play" or "wander". But, on the final few miles of rougher gravel road, with some ruts, etc., the steering wheel tossed back and forth and it was harder to control in rutted/rough places.
I will get it up on a rack to better inspect all of the steering components for any troublesome wear/play (nothing significant found when inspected on ground before purchase) and will replace any parts as needed. But, I suspect that there are no major wear problems there. So, two questions: 1. Might this be a common issue on rough roads with one ton trucks of this vintage and can it be corrected with a pneumatic "damper" (shock absorber?) on the steering cross link. A 69 K20 here with big tires had such a damper already installed when I bought it and it gives no such "tossing" effects. 2. Might this particular issue be centered in the steering gear box and can anyone tell me the best way to check for undue wear/play in that component? All helpful info will be appreciated.
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
07-21-2012, 10:33 AM | #2 |
Happy to be here
Re: Steering issue 1970 GMC 3500
Anyone?
