Old 07-19-2012, 11:26 AM   #1
LowDown
The only dumb Question ! 60-62
We've all heard it before , The only dumb question is the one you didn't ask.
I'm narrowing a disk limited slip that's at 65" hub to hub . The P-O put a different differential other than stock .Who knows what year truck it came out of ? I can't seem to find a definite size on any thread. My question is what is the hub to hub rearend measurement 60-62 out the box. Any input would be greatly appreciated.
LowDown is offline   Reply With Quote
Old 07-19-2012, 09:44 PM   #2
LowDown
Re: The only dumb Question ! 60-62
Really ? I'm the only one's ever swapped out a rear in a 60-62 before . come on guys little help here ?
Old 07-19-2012, 10:12 PM   #3
padresag
c,k,10-20-30. chev or gmc
10 series does not have hubs on the rear . k series does have hubs on the frt as does c
20 and 30 series do have hubs on the rear with full floating axles
be a little more specific where your measures are coming from
ron
padresag is offline   Reply With Quote
Old 07-20-2012, 06:03 AM   #4
LowDown
ron
Ron, I have a 61 c10 ,I just would like a end of drum to drum measurement. I'm more than likely taking 3 1/2" out of each side, that will put me at 58" . That should leave me plenty of room for playing with backspacing and wheel width. I just would like a idea of what the original from factory length was. Thank you, Ron .
Old 07-20-2012, 07:47 PM   #5
1971sierragrande
1971sierragrande's Avatar
Lowdown, I made a guick measurement by laying a tape measure across the tail end of the trailing arms, backing plate to backing plate was 56"
Hope this helps
1971sierragrande is offline   Reply With Quote
Old 07-20-2012, 08:24 PM   #6
LowDown
Hope this helps
Thanks a lot Sierragrande !
Old 07-20-2012, 11:29 PM   #7
Captainfab
60-66 Nut
The WMS to WMS of an original HO32 under a '60-'62 C10 is 62". It is the same for the '63 to early '70 12 bolt as well
Old 07-21-2012, 01:15 AM   #8
padresag
Good. had a pm with him today and thought that you would have the answer
ron
