Old 07-19-2012, 01:21 PM   #1
tex_waco_usmc
Project Heaven in my 67!!!
Frame Rivets
I am getting ready to cut holes in the cross member that the drive shaft goes through in order to weld big pieces of pipe in there and run my exhaust through.
What is the best way to cut those rivets out and then when I go to reinstall should I use grade 8 bolts or weld or both???
TIA...
tex_waco_usmc is offline   Reply With Quote
Old 07-19-2012, 02:19 PM   #2
RenoKeene
Florida Edition
RenoKeene's Avatar
Re: Frame Rivets
You can grind the heads off and knock em out with a punch. Bolt it back together with grade 8.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 07-19-2012, 02:28 PM   #3
tex_waco_usmc
Re: Frame Rivets
Could I use an air chisel on the heads or not such a good idea?
Old 07-19-2012, 02:34 PM   #4
RenoKeene
Florida Edition
RenoKeene's Avatar
Re: Frame Rivets
Sure, I did it both ways, seems it was less painful with the die grinder. They are a bear either way.
Old 07-19-2012, 02:36 PM   #5
tex_waco_usmc
Re: Frame Rivets
Is this even possible with the cab still on the frame?
Old 07-19-2012, 02:37 PM   #6
white 67
Re: Frame Rivets
If you have a air chisel the easies way to do is to cut a x in the rivit head with a grinder and used the air chisel to knock the peices off.
white 67 is offline   Reply With Quote
Old 07-19-2012, 02:45 PM   #7
magicoolbus
magicoolbus's Avatar
Re: Frame Rivets
X2
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
Old 07-19-2012, 02:48 PM   #8
tex_waco_usmc
Re: Frame Rivets
Didnt even think about doing it that way! I will give that a try!
Old 07-19-2012, 03:11 PM   #9
rsavage
rsavage's Avatar
Re: Frame Rivets
Any rivet I could get to with a drill, I drilled through with like a 5/16" drill. Then used angle grinder (if I could get at the head), air chisel (sharpening the chisels often) and a punch. I spent the better part of a day taking out a 4 speed crossmember out of my Burb. Took the rivets out of the automatic crossmember I replaced it with too so I could put the top ears in after I had the crossmember in. Used 1/2" grade 8 bolts to bolt it in and bolt it together. It isn't one of those things you do to your truck that you enjoy.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 07-19-2012, 08:57 PM   #10
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Re: Frame Rivets
Any idea where to get replacement rivits?
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
