Spring Bushings
I recently pulled a set of springs off a '63 K20. The bushings are shot. What size should they be? The inside of the spring with the bushing removed is about 1.15".
Re: Spring Bushings
why don't you just order them. various places have them. you also didn't specify which ones that you are after
ron |
Re: Spring Bushings
I need the bushings for just the springs. The shackles are fine. The bushings were worn though and the spring is egg shaped so it is hard to get a good measurement.
#4 | |
Re: Spring Bushings
perhaps you need new main leafs also ron |
Re: Spring Bushings
I probably do need new leaves. Mine are half thickness at the top of the eye.
