Old 07-19-2012, 06:59 PM   #1
48gmc
master cylinder
redoing all brakes and lines on my 48 gmc 1/2 ton...should i replace the master cylinder or rebuild it...would like to have two lines running out of master cylinder, but my master is on the frame, couldn't find one with two lines...
48gmc is offline   Reply With Quote
Old 07-20-2012, 04:36 AM   #2
droppedgmc
Truck Enthusiast
droppedgmc's Avatar
Re: master cylinder
I used one of these setups on a '54
http://www.classicperform.com/Store2...CP632BB-MC.htm
'85 swb
droppedgmc is offline   Reply With Quote
Old 07-20-2012, 05:50 AM   #3
48gmc
Re: master cylinder
will that work fine with drum brakes? i do you fill it from the top...it seems like it would be under the seat...
Old 07-20-2012, 12:03 PM   #4
Scottshotrods
Re: master cylinder
You can use one of those and they work good.You can use one of our remotor resv and remote filler caps we make that will allow you to fill it up from the firewall and make it alot easier to inspect.
Justin
www.scottshotrods.com
Scottshotrods is offline   Reply With Quote
Old 07-20-2012, 04:03 PM   #5
48gmc
Re: master cylinder
do you have a diagram on how it is hooked up...i don't get how it fills from firewall...
Old 07-20-2012, 09:37 PM   #6
Scottshotrods
Re: master cylinder
This is how it will be set up with our remote resv and remote lid
1.On the firewall on your truck this is where our Remote dual resv will mount.
2.On the master on your frame you will remove the factory master lid and install our remote master lid.
3.There will be some an fittings that come with our kit and these will thread into our resv and remote lid.
4.You will run some brake lines off these fittings and the lines will go from the remote resv on your firewall to the remotoe lid on your master.
The remote resv needs to be above the master and this is for gravity feed.
You can send us a e-mail and we can send you some more info if you would like
scotts@scottshotrods.com
Old 07-21-2012, 12:47 PM   #7
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: master cylinder
Thats a very cool idea. Completely solves my under dash mastercylinder problem.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 07-21-2012, 08:23 PM   #8
48gmc
Re: master cylinder
it is a good idea, but how do you tell when you hit the max level...
