mustang II
has anybody here used the welders series mustang II set ups from Paul Horton? http://www.welderseries.com/blog/online-store/21906/
![]() Join Date: Jul 2007
Re: mustang II
I looked at them pretty hard before I bought a different brand. Being "universal" you have to be up to trimming and fitting to get things setup rather than just measure, mark and weld.
If you haven't done so download their installation instructions and study them. |
![]() ![]() Join Date: Nov 2008
Re: mustang II
Not to hijack but what is the progression in IFS for Task Fotce trucks from cheapest to most expensive?
I'm guessing on the low dollar end it would start with a GM clip graft(?) - Then go to something like this universal Mustang II crossmember. - And on the high end I'm guessing the new Porterbuilt bolt on setup that Delmo is piloting But what's the progression in between? Heidt's, TCI, No Limit, yada, yada. What does everyone think (for a non show truck driver that might tow lightly like a pair of jetski's) could be best value vs ease of installation, etc? (FYI, I'd pretty much decided on Posey's Super Slide 2" lowering springs with or without a dropped axle or dropped spindles but it's obvious the prices stack up quick and worse, I'm hearing/reading too many bumpsteer concerns that there doesn't seen like there's a great fix for) Posted via Mobile Device Last edited by Dan in Pasadena; 07-20-2012 at 02:17 PM. |
#4 | |
Certified Car Nut
Re: mustang II
A grafted clip such as a camaro, monte carlo etc. would be the lowest cost, but were you to figure in rebuilding a 20 year old clip you could spend more than you thought. The next lowest cost would be a Mustang 2 unit. You can get them for 1200-1700 hundred depending on where you shop. I like Heidts and TCI if I were buying a Mustang 2, but that's only because I used those units. Next you can get a Flatout Engeering crossmember for 795. and depending on the price that you find a corvette IFS ( I see them on ebay for 400-500 all the time) you can easily have that setup for the same price as a Mustang 2 and maybe even less. If I had to choice to do it again I would probably go that route. Next up are your really nice setups such as Scotts, Heidts Superrides, Fatman stage 2, Jim Meyers, Art Morrison bikini clip, TCI custom IFS, No Limit, ect. I'm sure I missed some units but you get the picture. All are really, really nice and you can't go wrong. But we are talking over the 2 grand mark. Its all about what your wallet will let you do. The cool thing about the GM Clip, Mustang 2, and Flatout Engineering is you don't have to do it all at one time. You can buy a GM Clip that is in pretty good condition and it may not need to be rebuilt and of course you can rebuild it later. You can buy the Mustang 2 crossmember or the Flatout Engineering crossmember and buy the suspension parts later. Some times if you are like me you don't have all your funds at one time.lol Last edited by Kabwe; 07-21-2012 at 11:49 AM. |
#5 | |
Re: mustang II
Re: mustang II
My concern about bump steer is ONLY related to staying with a solid axle but lowering it in any way.
I forgot about the Flat Out Engineering Corvette based system. Anyone know if there'd be a concern using that if I want to occasionally tow my Jetski's? With a Corvette front end I'd almost feel compelled to use a Corvette IRS system. (I'd want to be able to say its an old Corvette w/a '55 truck body on top. Not that that would be accurate, but who - that I'd tell - would know, lol?!) Posted via Mobile Device |
Re: mustang II
Oh and PS: What about the old rhubarb that the Mustang II systems are too light duty for a pickup? Any truth to that or just alarmism? (Which is frankly what I suspect)
Re: mustang II
Doing a flatout on a AD, to me it is a lot more sturdy than the other MII. Don't have but about $1700 in it.
#9 | |
Yellow truck club
Re: mustang II
My truck had a Horton evolution front end. They do make nice stuff for north of the border.
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
Re: mustang II
Thanks guys. I was wondering what Bam used and went back to read his thread. Mustang II, natch. Doesn't mention what company though. If its good enough for him I'll seriously consider it.
Re: mustang II
What about the Jaguar front end? I've heard of it being used and can be a bolt on.
#12 | |
Certified Car Nut
Re: mustang II
Dan I put together the Mustang 2 on my truck with components from TCI and Heidts. I have a TCI crossmember and Heidts upper and lower control arms, and a t-bird rack and pinion. I have used TCI and Heidts units on others peoples rides and like them. Also as entourageguy said there is nothing from the mustang 2 car in a mustang 2 aftermarket kit other than the geometry. The name stuck because back in the day people use to use the suspension from the actual car on their trucks and streetrods. So of course companies started designing kits to make life easier base on that geometry. Anybody that tells you different does not know what they are talking about or are trying to sell you something. Are there better options? Yes but that comes with a bigger price tag. Thats why I like the flat out engineering kit because you can do it for about the same price as a mustang to kit if you shop carefully. I installed a couple of the crossmembers in some rides and I liked for the vette components. I do not see anything that makes the crossmember more sturdier than a mustang 2 crossmember. Same metal thickness and bascally the same weld area. By the way you don't need a flat out engineering crossmember to install the vette suspension. You can use the vette ifs only, but the flat out kits make it easier and in my opinion looks cleaner. coralhead, I include that with clips when I said etc. There are too many clips to mention. People also used volare and pacers. I have no personal experience with the installation of a Jag clip so I really can't speak on it. I don't speak on things I don't know about. I have talk to guys who have them and seen their installations. They seem to be happy with them. Last edited by Kabwe; 07-21-2012 at 03:25 PM. |
#13 |
Re: mustang II
@Dan.
Kabwe is dead on in his observations. This is the second task force truck I have owned with a camaro clip. The camaro clip gives the truck the heavier road manners of the 70's Gm cars. I have used my truck to carry heavy loads and tow. It gets the job done with confidence. If you want to feel how it rides and handles I will let drive my truck to help you make an informed decision. This is the clip job that no limit does in the "camaro clip no limit style thread". Maybe others in the L.A. area with other style IFS front ends will let you try theirs out? Posted via Mobile Device |
#14 |
Yellow truck club
Re: mustang II
For those that don't know I'm BAM thats why I'm answering Dan's question.
but he has been called a lot worse ![]()
#15 | |
Certified Car Nut
Re: mustang II
I want to change my username to BAM but I don't see the point in paying for the change when I'm already a paying member. I like this site alot, I think it is the best truck site so I pay to support it. I been think about the name change for a while because most of my buddy's call me Bam. Sorry I was thinking out loud.lol And yes I've been called way worst, I think you have a couple of choice words for me don't you.lol Last edited by Kabwe; 07-21-2012 at 06:33 PM. |
#16 |
Re: mustang II
Bam, thanks for filling in the rest of the story.
I HAD a Jag IFS and IRS in my '46 truck but whoever installed it never put in the upper shock mounts! I played with how to address that before something came up, I sold the trick and bought the '55 - which is my dream truck anyway. For some reason it just doesn't sit right with me to cut my frame in half. For that same reason I had kinda thought of keeping the straight axle with discs, PS, etc but the more I look into it the more the costs stack up. And though it'd be an optimized original truck, it'd also be a total compromise. I like the idea of TCI, Heidts or Flatout just cause they've been around a long while. I need to look into what you get in their kits, dollar comparisons, and. customer service support! Posted via Mobile Device |
#17 |
Re: mustang II
PS: The words I call Bam are: talented, helpful, nice guy, and friggin gorgeous '55 car owner - the car, not him!....ok, ok, he's not a bad looking man, ha ha. (I'm jealous as hell of him having both the car and truck too though)
#18 |
Yellow truck club
Re: mustang II
Good one!
#19 | |
Certified Car Nut
Re: mustang II
I saw Scotts IFS for the 55-57 trifives at the LA Roadster show and man was it nice. Everytime I go to show it teaches me just how broke I am.lol Last edited by Kabwe; 08-20-2012 at 01:02 PM. |
#20 |
Re: mustang II
Okay so help me out fellas. I was planning on getting the welders series subframe but I had my heart set on the C4 set up which I happen to live ten mins from corvette shop that specializes in C4s. I can get the complete front end for $400 or front and back for a grand. the particular one I want is coming from a 95 C4.
Which set up should I get? |
#21 | |
Certified Car Nut
Re: mustang II
http://www.flatout-engineering.com/ Last edited by Kabwe; 07-24-2012 at 03:31 PM. |
#22 |
Re: mustang II
How much lower than stock is the vette kit. With my long box truck I dont want to go too low.
1959 Fleetside Big Window Long Box Standard Trim soon to be Deluxe 1953 GMC Carryall Suburban |
#23 |
Re: mustang II
I actually went to the vette shop today and purchased a stock 85 set up complete with steering rack, lines swaybar, etc. and she is even throwing in the front half of subframe with the brackets.
#24 |
Re: mustang II
Thanks Bam
#25 |
Re: mustang II
well i scored big. I got a complete running 88 corvette for a grand. I can def take my time with this build now.
