GEARHEAD
Bucket seat under floor brace
I cut out the front floor seat brace from a blazer tub to use for bucket seats. Nice to have if you are installing original style buckets in your truck. I sand blasted it and it's in good shape. Three piece set, middle section and 2 outbord pieces. $175 shipped.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: Bucket seat under floor brace
sold if set is complete..
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
GEARHEAD
Yes, all three pieces sold together, just as seen in the pic.
Carpe manana
Will use for my K20 build. I assume the middle secton will conform to the floor pan though it came from a blazer. If you know different let me know. PM payment details when possible. Thanks, Pete
GEARHEAD
PM sent
It will fit perfectly, trucks that came with buckets had the exact same piece spot welded in. A must have piece if you are adding factory buckets and want to make it just like original. This will also make it easy for you to find the seat bracket hole locations, you will find it is about an inch outside the bench seat bracket hole location.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
#7 | |
Carpe manana
Anyone know for sure?
#8 | |
Always on the hunt...
![]() Join Date: Sep 2006
Carpe manana
Thanks Mel. This would not be a complete set then for a truck install. Bummer.
GEARHEAD
Actually, I believe these 3 pieces will work. If you have a bench seat now, you already have the outer braces front and back (they might need to be moved a bit). The ones you are needing are for the inboard mounts which are in the 2nd picture of post #14. In this case the long piece goes across the front, and the shorter pieces would be used for the inboard rear mounts.
If this isn't correct, the only way you will find the exact original style rear inboard braces is to get them from a truck or suburban that had bucket seats. Blazers are different because the seat brackets are different and the passenger side tilts forward.
#11 | |
Just a Member
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
#12 | |
#13 |
Moderator
![]() Join Date: Jun 2008
The extent of your knowledge never ceases to amaze me, Mel. Thanks for the great info!
-Richard
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
#14 |
A correct truck uses the long brace and four smaller braces (like pic). I would sell you a set but we are out of them.....Jason
72 Cheyenne Super 80 Silverado Blazer 2wd Last edited by sameyrasmea72; 07-22-2012 at 12:23 AM. |
#15 | |
![]() Sorry to high jack the thread hgs_notes..
Brett ![]() 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
#16 |
Carpe manana
Thanks for the post Jason!
#17 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Subscribed for the info
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#18 |
One of the First
![]() Join Date: Jan 2000
Here is some picture of a truck floor board for buckets - hope it helps.
Not for sale...
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
