Old 07-20-2012, 06:14 PM   #1
Liddy71
Liddy71's Avatar
turbo 400
I have turboo 400 I have order 2 dip sticks tube and stick and can't find one that will fit. do they make different sizes the ones I get are to big to go in the hole
Liddy71 is offline   Reply With Quote
Old 07-21-2012, 08:37 AM   #2
Desert1957
Desert1957's Avatar
Re: turbo 400
You are positive you have a 400? , Turbo 350's have a square looking pan with the corner cut off. post a picture of your trans or measure the hole in the trans. let us know.
Turbo 350
Turbo 400
Desert
Desert1957 is offline   Reply With Quote
Old 07-21-2012, 09:15 AM   #3
donut
donut's Avatar
Re: turbo 400
Another thing, my 400, the dipstick tube slid into a rubber grommet. It was not an easy fit and had to be manipulated down on the transmission. Even with lube, I had to use a pair of Channellocks to persuade it in.
I'll see if i can find a pic or link to the grommet.
When I got the new tube, they didn't ask as about the size, so I'd assume that they're pretty standard. Dipstick/tube came from the local dealership. 20-25 bucks. (iirc)
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 07-21-2012, 11:28 AM   #4
Firebirdjones
Re: turbo 400
Like donut mentioned, in later years they went to a rubber grommet style seal. This seal goes in the trans first, then the dipstick.
The older models used a simple o-ring on the tube itself.
Both of these tubes are made differently for the different type of seal.
It would help to know what year you are dealing with. The rubber grommet style didn't start showing up until around the mid 80's.
Firebirdjones is offline   Reply With Quote
Old 07-21-2012, 05:59 PM   #5
Liddy71
Liddy71's Avatar
Re: turbo 400
mine has the rubber in the trans the one I order has the oring. and yes mine is the bottom pan in the pic
