Old 07-20-2012, 10:56 PM   #1
emil77
Fuel hose valve?
Hi guys,
'72 Chevy C20...My fuel hoses are leaking, the ones inside the engine bay. I removed the hose clamps to take them off, but fuel is constantly coming out. I put a vise grip to stop the fuel loss. Is there a valve or something I can turn so the fuel stops leaking?
Thanks,
Emil
1972 Chevy C20
emil77 is offline   Reply With Quote
Old 07-21-2012, 02:41 AM   #2
emil77
Re: Fuel hose valve?
Anybody?
Thanks,
Emil
1972 Chevy C20
Old 07-21-2012, 03:03 AM   #3
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
unless you have a multi tank setup and switch it to an empty tank. the valve would be on the floor when you open the drivers door. other then that, no. If you can vise grip them and get them to stop, siphon or pump the tank. I have drank a little fuel trying to quick swap a fuel pump before.
"Instructions are just another mans opinion"
Become a Supporting Member
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
Old 07-21-2012, 04:45 AM   #4
John Pasinski
John Pasinski's Avatar
There are no valves to shut off the gas. It works by syphoning. The fuel pump then just basically pumps the fuel up to the carb.
I just take a 5/16, or 3/8 bolt (whichever size fits the hose) and insert it as quick as you can when you pull the hose from the fitting. That will pretty much stop the syphoning action. You can of course apply a small hose clamp to that if it continues to leak but the bolt by itself should be enough.
A man's thoughts devise his ways; but it's GOD that directs his steps.
John Pasinski is offline   Reply With Quote
Old 07-21-2012, 05:23 AM   #5
JimKshortstep4x4
You can stop the syphoning by loosening the line at the tank sending unit.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 07-21-2012, 09:32 AM   #6
emil77
I have this on the drivers side, but I only have one gas tank, if I turn the valve it should stop the flow of gas?
Thanks,
Emil
1972 Chevy C20
Old 07-21-2012, 09:48 AM   #7
So.Cal.Super
It'll Buff Out!
look under the cab and see if any hoses are connected. if someone bypassed it, then no. if its connected and you switch to a non existent tank, you should only get what fuel is in the line.
Man Card Rules
Old 07-21-2012, 09:54 AM   #8
emil77
Thanks!
Thanks,
Emil
1972 Chevy C20
Old 07-21-2012, 10:40 AM   #9
ole dollor
ole dollor's Avatar
if you jack the front of the pickup up that should stop the flow , or at least slow it down....
ole dollor is offline   Reply With Quote
Old 07-21-2012, 10:45 AM   #10
ole dollor
ole dollor's Avatar
Old 07-21-2012, 01:24 PM   #11
cdowns
cdowns's Avatar
blow air into the hose goin back into the tank to break the suction effect
