Old 05-20-2003, 05:29 PM   #1
GMC70c20
cab diff
we are changing cabs and I need to know if there is any
differences in between a 1/2 and 3/4 ton cab, if there is what are they.
GMC70c20 is offline   Reply With Quote
Old 05-20-2003, 05:43 PM   #2
1971Stepside
Almost Satisfied
1971Stepside's Avatar
no differences between 1/2 and 3/4 ton cabs..
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 05-20-2003, 06:56 PM   #3
Gee_Emm
The cab mounts on the frame are different for 3/4 tons
Gee_Emm is offline   Reply With Quote
Old 05-20-2003, 06:57 PM   #4
Gordo
Smile
Are the cabs of the same year? If not, there are diffs.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 05-20-2003, 11:04 PM   #5
Rod
True enough there are some differnces such as small back window in 67 cab ., but big back window was an option in 67,
67-70 cab used a different type gas tank,then a 71-72 as a 71-72 cab has a vent tube in the cab for a charcoal canister under the hood.... also 71 - 72 cab has vent holes in the door frame near the vin tag. 72 cab has no raised area for the rear view mirror.
Just a few differences I've noted, there are more but these listed are easy tell tale signs of a cab swap. Mind you some cab differences were carried over into the new year production.
Rod
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 05-20-2003, 11:43 PM   #6
Roberty
Hot Damn - Here I Am!!
Roberty's Avatar
I know that the big block and 4x4 trucks have the bolt in large hump floor. My friends 2wd Blazer with the factory granny geared 4 speed also has the bolt in hump. Do all the trucks with the 4 speed option have the big hump and what about the 3/4 and 1 ton trucks? All of them have the big hump floorpan?
Robert
My vehicles:
'90 Silverado Sport
'71 Chevelle SS Convertible
'70 C-10 - My Grandfather bought it new - original un-restored
Roberty is offline   Reply With Quote
Old 05-21-2003, 01:02 AM   #7
72 CustomCamper
huh ???
72 CustomCamper's Avatar
My 3/4 ton has the small hump... I thought it was just the 4 spd trucks...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 05-21-2003, 01:09 AM   #8
Dropt72Shortbed
Dropt72Shortbed's Avatar
i found another difference.
when removing my 72 cab and replacing with a 71 cab i notced the 71 cab hung down lower in those two little parts tha run down parallel to the frame rails, hard to describe what im talking about but i noticed this since the guy who installed the th350 in my truck ghetto rigged the shifter linkage, their was a bolt sticking up through the frame rail that was holding it together, on my 72 cab it cleared this bolt, on the 71 cab it did not clear.
also not sure if anyone mentioned above,
72 is first year for rear view mirror mounting on the glass
Dropt72Shortbed is offline   Reply With Quote
Old 05-21-2003, 06:02 PM   #9
Low69CST
The firewalls are different from 67-68 to 69-72's, also 72's have the screw in the door
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 05-21-2003, 06:39 PM   #10
jayssunm
jayssunm's Avatar
Also dont know what year they started (I have a 67 small window) but some have a cargo light (?) on the back of the cab above the rear window.
67 Fleetside Shortie, small window, slip & slide tranny
Upgrades--small block, tilt column, disc 5 lug conversion (front and rear),
Future Projects--suburban gas tank under the bed, rear roll pan, better gas mileage (currently about 6-10 MPG)
jayssunm is offline   Reply With Quote
Old 05-21-2003, 06:50 PM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
69 was the first year for the cargo light.
the high hump floors came in all 4 speed, all 4X4, all big block, and V-6 trucks, and blazer/suburbans.
Old 05-21-2003, 07:05 PM   #12
Roberty
Roberty's Avatar
The 72 2wd Blazer I just sold to a board member was a V8 turbo350 truck and it had the small hump floor. A friend of mine just bought a 2wd 72 Blazer with the granny geared 4 speed option and it has the big hump. The Blazers must have been just like the trucks as far as what transmission or if or if not it was a 4x4 as to whether it had the small hump floor or the big one.
Robert
My vehicles:
'90 Silverado Sport
Old 05-21-2003, 07:11 PM   #13
Longhorn Man
Yeah, I ment blazers/suburbans equipped with 4X4, big block or 4 speed.
I am now wondering about the V-6 cabs having high hups though....
My 69 GMC was a 305/Th400 originally. I thas a high hump floor, and is original. (still has original paint)
There is a 69 Longhorn (GMC) with a 305 and a TH400 on e-bay right now....low hump.
Interesting.
Old 05-21-2003, 08:57 PM   #14
CPNE
Resident Curmudgeon
CPNE's Avatar
One difference not mentioned is the throttle linkage. On 71/72 cabs, it's designed for the cable linkage. On 67-70, the linkage is a rod setup. Where the bracket for the pedal bolts is different and the 71/72 cab has a hole for the cable linkage not on pre-71 cabs.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 05-21-2003, 09:25 PM   #15
Gordo
Smile
I forget which years have what but the early models have a hand operated e-brake, later models use a foot operated e-brake.
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1951 Wife
Old 05-21-2003, 11:12 PM   #16
Longhorn Man
Gordo, that would be the 67/68 that have the hand brake.
Old 05-21-2003, 11:13 PM   #17
Longhorn Man
In '71 and '72, the drivers side door jamb got a black plastic vent that was not in there in 70 or earlier.
Old 05-21-2003, 11:59 PM   #18
jay-dawg
chevelito
jay-dawg's Avatar
could i put the hand e-brake in a foot brake cab?
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
Old 05-22-2003, 05:02 PM   #19
Gordo
Question
Thanks longhornmail, i figured it was somewhere around there.
jay-dawg,
I'm doing the opposite, I'm putting a foot e-brake assembly into a 68 cab. The basic thing in my way is the fuse panel and junction box. In your case it may be less trouble.
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1951 Wife
Old 05-22-2003, 11:34 PM   #20
Rod
I cant see why you could not just turn the fuse panel to an upward position like the 69-72 panel... should work. but you'll have some firewall insulation issues to work at.
