Old 07-20-2012, 11:56 PM   #1
stepside-mitch
stepside-mitch's Avatar
Steering knuckle scraping?
I'm running stock 15x8 rallys and the lower control arm of the spindle is grinding a little bit. Common issue but I also noticed that the steering knuckle digs into wheel. Is this also a common problem? I bought some cheapo 5/16" wheel spacers for the time being but they won't last. I really don't feel like grinding too much off the knuckle. Any help would be greatly appreciated.
By the way, they are McGaughys 2.5" drop spindles. stock springs
stepside-mitch is offline   Reply With Quote
Old 07-21-2012, 03:22 PM   #2
stepside-mitch
Re: Steering knuckle scraping?
anything? I'm completely stumped
Old 07-21-2012, 03:53 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
Are you talking about how drop spindles cause the lower control arm to rub the wheel?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 07-21-2012, 11:42 PM   #4
stepside-mitch
the steering knuckle where the tie rod end bolts to on the spindle
Old 07-22-2012, 12:09 AM   #5
rwhit57
rwhit57's Avatar
I had that issue but I believe on mine it was the tierod, there was plenty of meat to grind it where it wouldn't rub.
"Whoever said money can't buy happiness has obviously never seen a speed shop!
rwhit57 is offline   Reply With Quote
