looking for pics of 65 6cyl A/C brackets
I have my Grandpa's 1965 C-10 with a 230 6cyl and I am wanting to put A/C on it. I have several factory A/C setups but they are all for V-8 engines. I would like to retain at least somewhat of a factory appearance, I have thought of using a modern underdash unit and plumbing it through the dash and using the original A/C bezels I have, but I still would like to use the original style brackets and compressor.
Does anyone have a 64-66 factory or dealer installed 6 cyl A/C truck they can post pics of so I can see what it looks like? Does anyone know of a place to get these brackets other than wait for a set on Ebay? Thanks for any and all help PICS needed please
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
![]() Join Date: May 2005
Re: looking for pics of 65 6cyl A/C brackets
Good luck with your hunt as I have searched many times for the same picture or brackets. The best I could find was an early aftermarket under dash set up but without the bracket for the compressor. I did at one time have a picture of the original bracket but it has since been lost, I wish someone would find one and try and reproduce it, lots of L6s out here. The aftermarket air for L6s used a york compressor found one but the guy would'nt sell.
![]() Join Date: May 2012
I will try to get some better pics of the brackets for ya.! Mine may be a 250ci I
guess,it's a 66 c10. ![]() ![]() ![]()
Go Fast and Have Fun.!! My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185 |
This is after market under dash a/c.
Front of the bracket,bolts behind the water pump pulley just below the thermostat housing. ![]() This is the top of the bracket,looks like the first two head bolts are used. ![]() Another pic of the front were the compressor bolts to it. ![]() Hope this helps.
there is a guy on e-bay that might have what you are looking for. i bought a p/s bracket for my 70 292 good quality made.. just type in 6 cylinder a/c brackets , also has p/s and alt.brackets...hope this helps...
![]() Join Date: Aug 2011
If there is no difference between a 64 and a 65 then here is a 64 A/C bracket
that was on my 6cyl 250. which just happens to need a new home.
http://s994.photobucket.com/albums/af62/ScottAz2/ |
#7 | |
here is my 230 in my truck
I dont think i can use yours McCoy it looks like it will bolt were my power steering pump is
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
1963 were the same as the passenger cars. In 1964 they changed to a cast bracket? I have a cast bracket that I won't be using now that I have the correct one. When I look on craigslist I look for adds featuring inline`s, they don't often advertise A/C brackets. Found two others that way, though I did not purchase them.
Call him and ask if you could buy just the A/C brackets and compressor.
http://dallas.craigslist.org/mdf/pts/3141088103.html |
So are the brackets the same between 63 and 64 except one is cast and one is stamped steel?
So the picture you posted is what I need to be looking for?
#13 |
The picture I posted is from the 1963 Custom Accessories Installation Book. The bracket is stamped steel. The cast bracket I have from a truck in Texas was located in the same position. I was there when they removed it.
When I started looking in the parts book, the part number changed in 64. I've read that they went to a cast iron bracket instead. You can get a compressor aftermarket rebuilt. The Craigslist ad states the brackets are from a 1963, if that's true, then they would be stamped steel. Hope I have not confused your thread to much. Maybe someone has the 65 Custom Accessories Installation Book to confirm. |
#14 |
And if it looks like your big HEI will conflict with mounting the compressor on the passenger side, Tom Langdon sells a "mini" HEI which looks like the stock points distributor. I bought one, and it clears my Sanden compressor on my 292 just fine.
292 + TKO500 |
