Old 07-21-2012, 11:12 AM   #1
willett
Another Day, Another Dollar
willett's Avatar
Question Rust hole on firewall above wire harness
Hey,
I'm fixing up a '73 cab for my '78 and I'm finding quite a bit of rust (no big surprise up here). Most of the holes are no brainers to fix but this one has me a bit stumped:
The hole is above the mounting spot for the wire harness on the top left corner.
How have you guys dealt with the problem?
Every time water gets into the cowel it ends up on the driver side floor pan!
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 07-21-2012, 12:13 PM   #2
notyo_cheez
Re: Rust hole on firewall above wire harness
My donor cab had minor rust out along the cowl seam on the firewall, the seam sealer shrank over the years and pine needles decayed inside the gap. I just used some fiberglass filler and covered it up.
notyo_cheez is offline   Reply With Quote
Old 07-21-2012, 12:13 PM   #3
legendman
legendman's Avatar
I had the same problem on my 82 K30, any water in the cowl area where the wiper trans is would run to the l/s and there was a hole rusted through there.
I made up a piece from some sheetmetal and welded it in then sealed it up with some seam sealer. Checked after a couple days after the sealer died and ran a bunch of water in that area and no more leak.
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 07-21-2012, 04:55 PM   #4
willett
willett's Avatar
I was thinking about spraying rhino liner or undercoat or something similar in there once she's all Sean sealed and patched up. What do you guys think?
Old 07-21-2012, 05:29 PM   #5
snm95ls
I'd think that a good epoxy primer and urethane seam sealer ought to do the trick quite well.
I guess a bed liner type of material could work, but I wouldn't want the texture in there as I would think that it would tend to hold water and debris.
snm95ls is offline   Reply With Quote
