1963 chevrolet c10 interior colors
hi,does anyone have the interior paint code for that dull goldish looking dash paint and the white thats on the speedo bezel and loer dash under the cluster,steering column etc ??? thanks
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: 1963 chevrolet c10 interior colors
I think they used Cameo white on the dash. They used Cameo white on the exterior two tone as well.
Fawn Beige was used on the interior only, seems they did not need a color code as this was the only color you would get. |
hi,and a much appreciated thank you for the info !!!
2003 Nissan Sunlit Sand, code "EVO" is a good match. I sprayed Spies Hecker basecoat reduced 50%, then added 15% hardener to that volume to get a finish that looks much like the original lacquer. Adding the hardener gives it a slight sheen and helps seal the basecoat so it's more durable. It's still not as tough as clear or single stage, so you've got to be careful about what you clean it with. Keeping spray furniture polish (Pledge in aerosol can) on it helps a lot.
![]() ![]() Posted via Mobile Device
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
thanks for the tip !!!
#7 | |
hi i was wondering were you got that seat cover for your truck Theastronaut
Chevrolet for life.. ![]() 1963 chevy pickup |
#9 | |
Thanks!
