Old 07-22-2012, 02:40 AM   #1
basshawk
73-87 Brakes on a 64 "Brakenstein"
I have done the 73-87 front and rear end conversion on my 64. I dont think I can fit a brake booster with my big block, so I have decided to go with manual brakes. My plan is to get a master cyl. from a 67-72 w disk brakes and I think that it will bolt directly to mt firewall. My question is: does anybody think that my brakes will function correctly with this combo? Also how do I tell the difference between a manual and power master cyl if its not on the car? Any help will be appreciated.
basshawk is offline   Reply With Quote
Old 07-22-2012, 02:49 AM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: 73-87 Brakes on a 64 "Brakenstein"
Here's a couple threads on a similar topic:
http://67-72chevytrucks.com/vboard/s...d.php?t=440292
http://67-72chevytrucks.com/vboard/s...d.php?t=444101
66 C20 Service Truck:
Old 07-22-2012, 07:54 AM   #3
hd74
i put a power brake booster on my 63 with a bbc it fit no problem
hd74 is offline   Reply With Quote
Old 07-22-2012, 07:59 AM   #4
hd74
Old 07-22-2012, 09:46 AM   #5
Chevy Fleetside
Chevy Fleetside's Avatar
Big Block. Power brake booster. The picture with the blue one is from a 79 Chevy Truck. My truck is a 65.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 07-22-2012, 11:41 AM   #6
chevyrestoguy
chevyrestoguy's Avatar
A BBC and a power brake booster can be done. It's really close, but if you use a stock-height valve cover, it'll clear.
You really need power brakes to stop one of these trucks in a panic situation. Another option would be a smaller diameter booster, but I think you'll be fine using your donor booster.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 07-22-2012, 08:50 PM   #7
FreakyMalo
FreakyMalo's Avatar
You'll want to compare the master cylinder bore diameter between the early and later master cylinders. If the bore is the same as the later master, you should be fine as far as brake function goes.
If you're serious about manual brakes, I suggest you do a lot of squats to build up your quads for maximum pedal pressure..
66 Carryall
my photos
FreakyMalo is offline   Reply With Quote
Old 07-23-2012, 12:00 AM   #8
Captainfab
60-66 Nut
Power brakes with a big block is no problem at all. I wouldn't even consider manual brakes any more. Valve cover clearance is not an issue unless you go with some really tall covers. You could also go with hydroboost. I have the brackets to make either a simple bolt on install, aside from the pushrod.
Old 07-23-2012, 01:50 AM   #9
basshawk
I allready have tall valve covers and would like to use them. Here is the bracket that i allready bought from Captain Fab. I have also added picture. What is the smallest diameter booster that will bolt up to this bracket? Captain can you tell me what year/model booster will bolt to your adapter? Maybe I could remove my brake booster every time I need to take off my valve cover? Or is this enough clearance and I'm just trippin? Feedback would be appreciated as I am anxious to do a power brake burnout!
Old 07-23-2012, 02:27 AM   #10
basshawk
Would this work? When I pull my VC, I end up with 4.5 inches to the centerline of my master cylinder. This is a 9 in booster which would leave me with 0 clearance when i would pull my valve cover. It is listed for a cars only. Could I use a car master? http://www.summitracing.com/parts/SU...ke%7cCHEVROLET
Old 07-23-2012, 02:46 AM   #11
basshawk
Or this, but $$$
http://www.classicperform.com/Store/...ck/6062BB2.htm
Old 07-23-2012, 08:21 PM   #12
basshawk
Decided to go Hydraboost. I have a huge cam and my power brakes may not work anyway. How much is the bracket captain?
Old 07-24-2012, 01:40 AM   #13
Captainfab
60-66 Nut
The hydroboost mounting plate is $25.00 for bare steel plus $5.00 for shipping. If you want it powder coated that is an extra $6.50.
Old 07-24-2012, 01:51 AM   #14
basshawk
Ill PM you when im ready to go. Thank you Cap.
