Old 07-22-2012, 04:53 PM   #1
crewcabshorty
crewcabshorty's Avatar
body side moulding
can anyone give me a idea on the measurement of where my body side moulding should be located on my 1987 fleetside ? i know on the rear it should be just under the tail lights , but on the front i am not sure .
crewcabshorty is offline   Reply With Quote
Old 07-22-2012, 05:01 PM   #2
pontgta
pontgta's Avatar
Re: body side moulding
On the Rear, you should have holes for the moulding corners, and that should give you a guide.... I used masking tape to lay mine when i painted the 87 longbed. It should almost lay at the bottom of the fuel tank door... but the rear corners should give you the best guide
pontgta is offline   Reply With Quote
Old 07-22-2012, 05:46 PM   #3
chengny
chengny's Avatar
chengny is offline   Reply With Quote
Old 07-22-2012, 06:07 PM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
the masking tape is a good idea thats how a professional installed mine while it was getting painted... he ran a piece from the front to rear of the truck and lined up moldings that way
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 07-22-2012, 07:19 PM   #5
ont_guy_38
ont_guy_38's Avatar
I'm pretty sure I took masking tape and run it from under the front marker light and then to the rear molding and that worked out perfect for me. This put the molding in the proper location on the gas tank door. Find an area where you can stand back a long ways so you can see how straight it is then put it on . Make sure you clean the area with alcohol good so it stays stuck
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
