Old 07-22-2012, 05:47 PM   #1
tenminutes
Wheel Expert Needed for 79 2wd K5 Blazer fitment
Newbie here and I need some specific offset help. I'm looking to build a "camaro SS" theme 2wd blazer. Bagged 79 K5, and I want to make the 22X10 5X4.75 +50 camaro SS replica's work. I haven't ordered anything yet but I'm curious if custom spacers will get it done, and if so what the recommended size would be, or it's going to take cutting and adjusting the axles?
The renderings I've come up with look great, now it's just figuring out how difficult and expensive it will be to make it work.
tenminutes is offline   Reply With Quote
Old 07-23-2012, 10:38 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Wheel Expert Needed for 79 2wd K5 Blazer fitment
Welcome to the forum tenminutes. I have no idea what the backspace equates to on those wheels so its hard to answer your question.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-23-2012, 09:24 PM   #3
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
My guess is you'll be using wheel spacers to get the backspacing correct. Not exactly something I'd want to do in a performance oriented truck. Or any truck I wanted to actually drive.
Anyhow, you're first problem will be redrilling your rear axles, drums and a set of front rotors for that bolt pattern. 2WD half ton trucks are 5x5 with 1/2"-20 wheel studs stock.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 07-24-2012, 01:55 AM   #4
andrewmp6
Get you a percy's wheelrite its 80 bucks at jegs or summit racing,It will let you test fit any rim and tire combo so you know if it fits or where you need to cut.
andrewmp6 is offline   Reply With Quote
Old 07-24-2012, 10:22 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
i understand that early gm rims (eg 72 buick) rims will fit
may need to look out for that type/size
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
