07-22-2012, 06:09 PM | #1 |
Robert Olson Transport
WHat did you get done 7/22/2012 edition
nothing truck related for me you all?
07-22-2012, 06:50 PM | #2 |
Re: WHat did you get done 7/22/2012 edition
I installed a radio and speaker in the dash. Cleaned out the interior, ripping out the nasty carpet and dash board. Removed a huge ball of useless wires left by the PO. Got most of my steering wheel "un-sticky'' using a little bit of carb spray, water, scotch bright pad. Next we will be polishing up hubcaps and repainting the wheels white or black.
1978 C10 Silverado Big 10 350/350.. play toy 1990 V1500 Suburban 350/700r4..Daily driver 1987 K10 Silverado 383/400.. Wife's rig WRECKED! 1989 V2500 Suburban 350/400.. SOLD! 1974 C10 Custom10 LWB 350/350.. SOLD! 1974 C10 Custom10 SWB 350/400.. SOLD! 1999 Silverado Z71 LS1.. Wife's rig WRECKED! On the hunt for a new project....... I'm a Chevy guy.....I'm just not a "NEW" Chevy guy. |
07-22-2012, 08:06 PM | #3 |
Old Heap Driver
Dumped the transmission in my 50 (TH-350), going to check around this week for prices on a rebuild. That's why we call them "Projects"! LOL
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
07-22-2012, 08:11 PM | #4 |
just this, its slow going
1986 gmc shortbed (right now its rough) porterbuilt dropmember front mmw flat plate uppers and lowers, soon to have porterbuilt rear dropmember, painted cherry red rallies, flat green primer in the works with a gloss white roof, 92 civic dx daily beater, 01 z06 new toy |
07-22-2012, 08:41 PM | #5 |
Pulled and regreased my distributor, cleaned my plugs off and replaced a charred plug wire trying to solve a miss im having. Havent got the dist reinstalled however, feeling kinda burned out working on it in the 100+ degree Texas heat.
Posted via Mobile Device |
07-22-2012, 08:48 PM | #6 |
Fire that truck up at nite with no lights on and see if you can see any spark's.
That's how I accidentally found my miss on my Suburban.
07-22-2012, 08:56 PM | #7 |
That was actually gonna be my next step after i drop the dist back in. hope i can track it down pretty easily.
07-22-2012, 09:19 PM | #8 |
No No
not much truck im still waiting for my tags been over 30 days making me mad. did install my sub setup I had in my fire bird into the wifes Saturn. that woke the stereo right up. now it sounds good just more full sounding
Posted from 67-72chevytrucks.com App for Android
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
07-22-2012, 09:21 PM | #9 |
Went to the bone yard....got the inner brackets for bucket seats out of a suburban and the under dash harness for power windows..also grabbed a speaker for my wife's trailblazer..
07-22-2012, 09:21 PM | #10 |
Finished up the TBI wiring harness for my 84' except for some connections that have to be made in the truck (namely, the other side of the ppl/white wire that serves as the crank signal for the ECM, battery power, and the switch input for my ignition relay), got a new fuel pump and sending unit installed in my new 20 gallon EFI tank, and got the tank crossover lines installed in the truck in prep for the EFI switch valve.
07-22-2012, 09:55 PM | #11 |
Not to much. Mounted a review mirror bracket. Cleaned my bed out to.
1979 Sierra Classic Heavy-half 1996 Silverado x-cab "the daily" |
07-22-2012, 10:11 PM | #12 |
Scored some NOS vent windows.
John 82 Chevy Silverado 350ci/TH350 |
07-23-2012, 12:28 AM | #13 |
Put the dash back in the truck, went to the white house truck show, then went and picked up some wood and got started on my workshop
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
07-23-2012, 12:50 AM | #14 |
Drag Racer
i actually did quite a bit
yesterday i FINALLY found time to wash my daily driver (2001 dodge ram 2500 cummins diesel) and i got my dads car out and drove that around a bit (2003 ford Thunderchicken) today i went to a car show and scored a top 50 award. Came home and truck was BADLY missing on the top end of 2nd gear (completely losing power when 3/4 throttle or more was applied, letting back out of it to have it coughing, farting, hiccuping etc) so i went to my Oreillys and picked up some tune up parts......pics of parts to follow, first of all, heres som epics of old plugs (been in truck 10-12 yrs, 25k miles on them) plug wires were horrible, looked like burnt insulation etc on them Out with the old In with the new Mind you, the plug wires were a cut n make your own kit.....never done that before, complete mess and confusion, BUT i got them done and they work. Fuel system cleaner is to hopefully help with that loss of power issue, if its not the filter, hopefully its not a weak pump, if so, their cheap! Cap, rotor and coil are all self explanatory as well as fuel filter. Took about 3-4 hrs till it was all done, longest part of it was fighting those dang plug wires!
Zach Hall 1983 Chevy C10 R/T: .194 60': 2.322 330: 6.379 1/8: 9.803 MPH: 71.37 1000: 12.781 1/4: 15.314 MPH: 88.79 Last edited by ProStreet83C10; 07-23-2012 at 12:56 AM. |
07-23-2012, 01:22 AM | #15 |
At the body shop.
No square doings. Its at the body shop and making me angrier.
But did get new rotors, pads and re packed bearings in my crew cab. Posted via Mobile Device and got the bunch washed.
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 07-23-2012 at 01:30 AM. Reason: pics |
07-23-2012, 06:10 AM | #16 |
Started pulling parts off. Getting ready to pull the motor and trans.
07-23-2012, 12:43 PM | #17 |
i went and bought another crew. 1980 GMC Seirra Classic 35 3+3 4x4
1969 chevy camaro Z28 #matchin Factory 4wheel disc 1969 chevy cst10 big block overdrive 5/7 drop dog dishs 1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s 2004 gmc sierra dually 4/4 lowering daily driver |
07-23-2012, 02:49 PM | #18 |
Always a work in progress
I just about finished up with my LS swap. She is running but still needs a tune.
I also finished putting her back together and loaded it up on a trailer to take over to the tuner.
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
07-23-2012, 03:15 PM | #19 |
Finaly had some time to work on the truck,installed a new fuelpump, and set the timing. Runs much better now, should have changed that pump long time ago.
Tom.______________________________________ The fleet: 2007 BMW 530xi M (daily driver) 1986 C-10 Stepside (project "my time") 1992 Corvette cab (summer time daily driver) 1969 Cadilac DeVille Cab ("it just need some paint") |
07-23-2012, 08:32 PM | #20 |
Installed some new MSD plug wires and wire separators. Sure runs better now that the old plug wires are not shorting to the headers. Just need to install all new belts, re-charge the A/C and get the exhaust work completed. Should be driving it in 2 weeks or less. This d@mn heat sure makes it tough to do anything on it. Been 100 degrees or more every day now for 3 or more weeks.
Jeremy I have done so much, for so long, with so little, I can do anything with nothing! 1984 GMC Sierra Classic-1/2 ton-SWB (R.I.P.) 1986 GMC Suburban 3/4 ton 4x4 2014 GMC Sierra LTZ Z-71 Crew SWB |
07-23-2012, 09:45 PM | #21 |
I mounted my new tires and rims.
07-24-2012, 12:37 AM | #22 |
other then the cowl hood i want your truck lol
07-24-2012, 12:53 AM | #23 |
finally got my 5.3 for my truck!! cant wait to get this built and in! life is good right now.
07-24-2012, 01:06 AM | #24 |
Got my ten bolt in at randys ring and pinion and getting a detriot truetrac and 373 gears put in
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
07-24-2012, 12:23 PM | #25 |
78K & 79C Jimmys
got my CB/radio in
front speakers and a dome light control pass side
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
