Roto Reuter thats the name...
![]() Join Date: Feb 2010
What is missing from this rear crossmember?
Can someone tell me what is missing from this rear crossmember. There are two bolts that are captive in the frame and it looks like there might have been something that goes around the drive shaft maybe. Pictures would be helpful. This is on my '69 C20 truck. Thanks for your help.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
![]() Join Date: May 2010
Re: What is missing from this rear crossmember?
Interesting. Is that cross piece with the bolts riveted on? All I can say is that my 69 3/4 ton with coils in the rear doesn't have that piece and never did.
Here's the best picture I can find: Last edited by FirstOwner69; 07-22-2012 at 08:56 PM. Reason: Attached picture. |
Since the lower bracket is riveted, it's probably factory. The upper bracket is bolted so likely was added later. Maybe it originally had the U shaped bracket type center shaft support and was later modified to accept the hanging rubber donut type that is shown in your pic.
I found two pics of mine showing the same location (partially) on my 69 C20. The upper bracket is riveted and there is no lower bracket.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
My69 has that it's for the wide style carrier bearing two piece drive shaft I'll post picture if I can find it
Posted via Mobile Device |
The crossmember piece is riveted to the frame, and the bar going across the bottom of it is also riveted to it. Thats why the bolts are captive and cannot be removed. I'm not sure what bolted up to it.
Here you go
![]() Posted via Mobile Device |
#7 | |
Does anyone know the difference in the two styles of driveshaft supports? What years where they on? Is mine OK the way it is?
My truck was equipped with the granny four speed trans maybe that's the difference and the autos got the hanging type maybe someone else can chime in.
Probably. As I stated above, mine has always had the top mount carrier as you have installed. Mine's a 350. Does anyone know if the big block used the other style pictured above for your bracket?
A look at the NAPA site for 69 C20 parts gives this info.
Driveshaft Bearing & Support Part Number: BRG HB88107A Product Line: NAPA Bearings IMPORTANT INFO: w/ Leaf Spring Suspension Driveshaft Bearing & Support Part Number: BRG HB206FF Product Line: NAPA Bearings IMPORTANT INFO: w/ Coil Springs
My truck is a c/10
#12 | |
