07-22-2012, 08:48 PM | #1 |
fuel gauge not reading with lights on
I had to pull my 72 tank out that had a hole in it. I replaced it with a 70 tank and sending unit. When I turn on the headlights the gas gauge drops to empty. I have checed the wire for crackes or grounding out some where. Any ideas????
07-22-2012, 09:38 PM | #2 |
Rottenwood Garage Member
Re: fuel gauge not reading with lights on
I had this problem with mine last weekend- it was a burned ground trace on the cluster circuit board.
Easy fix was to run a ground wire from the 1/4" ground lug screw on the gauge cluster to a convenient spot in the dash. |
07-22-2012, 09:52 PM | #3 |
i will look at that, thanks
07-22-2012, 10:14 PM | #4 |
Msgt USAF Ret
Pull the panel lights fuse out of the fuse panel and see if it still does the same thing.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
