Old 07-22-2012, 10:28 PM   #1
Big-Blue
Big-Blue's Avatar
How much hp is too much for my axles and axle u-joints?
So my front end is carrying a 1971 Dana 44. I am rebuilding everything from the pumpkin out, ball joints, bearings, etc. I am dropping a 504 hp 383 in it and started to question if that may be a bit much for the stock axles and u-joints at the axles.
I won't be doing any rock crawling, just hauling and an occasional mud run.
I am in no hurry and I have it all apart so should I upgrade to some after market axles and joints? Is it worth the extra cash?
Big-Blue is offline   Reply With Quote
Old 07-22-2012, 11:08 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: How much hp is too much for my axles and axle u-joints?
Auto or stick? What gears, and what size tires? all of those will have an impact on what will break first.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-23-2012, 12:20 AM   #3
oldspowered67C10
Dana 44 is a decently strong front axle, that engine I'm sure makes enough power to break something inside but it'd have to be in a pretty abusive situation to happen. Id run it stock and see what happens, especially if your going to leave it with a open differential and aren't going to go too crazy with tire size. Typically the front drive shaft is the weak link.
oldspowered67C10 is offline   Reply With Quote
Old 07-26-2012, 10:29 PM   #4
Big-Blue
Big-Blue's Avatar
Thanks guys.
35" mud radials with 4.10 gears. Turbo 350 tranny.
She's tore apart now and I would hate to do it again. It does make sense to wait and see though.
Thinking about upgrading the u joints and leaving the axles stock.
Old 07-26-2012, 11:05 PM   #5
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
You can swap in the 1973 up Dana 44 axle and stub shafts, the axle shafts dont neck down like pre 73 shafts and they use a slightly larger u-joint. Its a small upgrade but you should be able to source out the parts pretty cheap and definatly worth doing while your in there.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 07-26-2012, 11:31 PM   #6
mud.man.rj
mud.man.rj's Avatar
Don't see it being a big deal, used to mud race with 39" Boggers on my last truck with over 500hp and my new (old) 71 1/2 ton has over 500hp running 35" tires and I do abuse my trucks regularily, but not full blast off idle, just work my way into it. They are strong diffs and by what you stste should last you a long time. As mentioned the front drive shaft is the main weak link.
mud.man.rj is offline   Reply With Quote
Old 07-27-2012, 10:28 AM   #7
pumpkin
pumpkin's Avatar
With 35's and 350 hp If I got on it I break axles and or u joints. I went to chrome molly axles and a CTM style ujoint and no more trouble. In a straight line there was no problem, but as soon as a bit of power was applied with the wheels turned,,,,,snapp. Chrome mollies fixed that,,,,,,,,,for now.
pumpkin is offline   Reply With Quote
