07-23-2012, 03:05 AM | #1 |
Moderator
72 OEM Posi Carrier
Here is a nice OEM posi carrier from a 72 1/2 ton, 12 bolt rear end. It is a series 3 carrier (had 3.07 gears). It was tested and thoroughly cleaned by a local driveline shop. It was swapped out only because a series 4 carrier was needed for 4.11 gears.
$300 Shipped in the CONUS.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
07-23-2012, 06:36 AM | #2 |
Re: 72 OEM Posi Carrier
Will it work with my non position rear? Use the same axles?
Posted via Mobile Device |
07-23-2012, 06:37 AM | #3 |
Oh yeah put me in line on this
07-23-2012, 08:01 AM | #4 |
Just an FYI for anyone wanting this, you can run a ring gear spacer with a 3 series posi and use the 4.10 and numerically higher gears.
07-23-2012, 04:33 PM | #5 | |
Moderator
Thanks for the info
07-30-2012, 12:43 PM | #6 |
Moderator
Still available. No response from Leroy.
07-30-2012, 08:59 PM | #7 |
I forget if I need a 4 series or 3 for 3:73's...
07-30-2012, 09:05 PM | #8 |
67-72 parts collector,…
Richmond makes ring and pinion gears to work on the 3 Series carrier all the way up to 4.56 gears.
(thicker ring gear) Likewise they make a 3.73 set that will work on a 4 Series carrier. http://www.richmondgear.com/07Apdfs/page27.pdf 3.08 49-0068-1 40-13 3 3.42 49-0070-1 41-12 3 3.73 49-0072-1 41-11 3 3.73 49-0280-1 41-11 4 4.10 69-0204-1 41-10 4 4.10 69-0350-1 41-10 3 4.56 69-0206-1 41-9 4 4.56 69-0352-1 41-9 3 4.88 69-0298-1 39-8 4 5.13 69-0300-1 41-8 4 5.38 69-0302-1 43-8 4
07-30-2012, 09:10 PM | #9 |
I guess I should have been more specific. I have an oem 3.73 carrier currently
07-30-2012, 09:13 PM | #10 | |
Oem 3.73 carrier is a 4 series.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 07-30-2012 at 09:48 PM. |
07-30-2012, 09:15 PM | #11 |
Is this the factory Eaton 12 bolt? If so put me in line
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
07-30-2012, 09:24 PM | #12 | |
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White |
07-30-2012, 09:37 PM | #13 |
Carpe manana
I really don't know much but I read that OEM 3.73 12 bolt rears needed a 4-series. If I knew a 3-series would work I would probably take this carrier for use in my K10.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
07-30-2012, 09:44 PM | #14 |
Moderator
It is. You are up if you want it, thanks.
07-30-2012, 09:47 PM | #15 | |
I was incorrect. I found this on the net,... 12-Bolt Truck Rear Info: You have 3.07 gears & a 3-Series Carrier which used OEM 3.40 & numerically lower gears. 4-Series Carriers used OEM 3.73 & numerically higher gears.
07-30-2012, 10:21 PM | #16 |
Do you still have the gearset as well?
I'll get in line...
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 |
07-31-2012, 11:21 AM | #17 |
How would u like payment? I'll take it. Thanks
07-31-2012, 12:36 PM | #18 |
Restoration Virgin!
I've read that you could use a wider ring gear if you want to put 3.73's in a 3-series carrier....now I gotta find where I read this
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
07-31-2012, 01:04 PM | #19 |
I bought the last factory Posi that Leddzepp had. The packaging alone was top notch..
07-31-2012, 07:46 PM | #20 |
Ill get that payment right out to you. Thanks!
08-01-2012, 09:24 AM | #21 |
Paypal sent. Thanks Zepp!!!
08-04-2012, 10:35 PM | #22 |
Received to my house today. Fedex delivered it on Saturday! Looks great. Packaging was stellar! I would highly recommend Leddzepp to anyone wanting to buy something, you will not be disappointed. Thanks again sir.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! Last edited by El Campo; 08-04-2012 at 10:44 PM. |
08-04-2012, 10:46 PM | #23 |
08-05-2012, 02:28 AM | #24 | ||
Moderator
Lolife99 and others chimed in and added great info so I did not think it was necessary for me to respond.
08-05-2012, 03:02 AM | #25 |
Which companies produce 3:73 posi carriers for our 12 bolt rear ends? I know eaton does but what are all the rest? Sorry to hijack ledzepp!
