Old 07-23-2012, 08:24 AM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
Mechanical or Electric Gauges
I am wanting to start buying my Auotmeter gauges 1 or 2 at a time and start putting them in the truck. I already bought a ProComp Electric Water temp gauge and I am looking to buy the oil pressure gauge next. Do you prefer mechanical or electric senders? Why either way?
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 07-23-2012, 03:05 PM   #2
dieseldawg142
dieseldawg142's Avatar
Re: Mechanical or Electric Gauges
i installed sport comp gauges in my truck last winter. went with electric, no lines running into your cab. i found them to be fairly easy to install, i have pics of every thing i did, plus the wiring colors if you are only changing the small gauges. the small plug i pigtailed in for the temp/oil/volt/vac.
dieseldawg142 is offline   Reply With Quote
Old 07-23-2012, 05:53 PM   #3
C-10 simplex
They are both good, but my thought(s) is/are that unless you drive only during the daytime, you have to wire them for light anyways.....
In that case, why not go with electric?
i am using both electric(tach) and mechanical(temp). i think the wiring routing is easier with electric---because you can pretty much route the wires anyway/anywhere you want. With mechanical, i feel there is less leeway----i didn't have as much flexibility with routing with the sender tube AND it is a fixed length whereas with electric you can make the wire as long or short as you want. Of course, there is probably a way to make the sender tube longer or shorter but i don't know how at this point.
The reason why i am using both types is because i had the mechanical laying around and didn't feel like spending more money.
C-10 simplex is offline   Reply With Quote
Old 07-28-2012, 08:28 PM   #4
JMurray
Does anyone have the plug layout for the stock gauge cluster I am thinking of just hardwiring my stock gauges, My printed circuit is bad and don't want to mess with getting a new one, I am already running a mechanical oil pressure gauge.
82 GMC SW 2WD, 454 TH400, shaved mirrors, drip rails, tailgate, emblems. Midnight Blue, black and grey interior. Father son project in progresss.
JMurray is offline   Reply With Quote
