A/C Compressor Replacement
I'm having trouble finding the proper A/C Compressor for my 85 Silverado.
I had a estimate to replace mine at a small shop and they said $790.00. I about fell on the floor, that was $200.00 off since they fixed the leak in the lines that I had and won't charge me to recharge the system again.: . It took 4 different places to fix that so it cost me to refill the Freon 4 times at $70.00 a shot. ![]() I tried a couple places on Ebay to find the compressor but they were a little stumped. Here is the last answer I got. "Thanks for the inquiry! Yes, there will be a difference. If you look under product notes in the compatibility table there are differences in the diameter of the pulley, number of grooves, and the position of the connector. Unfortunately I can't tell from the VIN so you would have to look on your unit and compare it to the notes on the following units: 7511246 7511247 7511357 7511369 Unfortunately I don't stock all of them but if you type those numbers into eBay you can at least read the descriptions." I tried typing those numbers into google and got nothing to do with my compressor. Here is a picture of my compressor if this will help. My clutch dosen't kick in so I need to just replace the whole thing since I'm not a mechanic. Thanks Guys Jack |
Re: A/C Compressor Replacement
$790 doesn't sound out of place if that was a new compressor included.
I beleive that style compressor you have pictured is still available new (not rebuilt). There is a Sanden model as well that fits that style. If it makes you feel better, my neighbor took his 69 Ranchero in to a local AC shop with a great rep (I've used them too) and that big ole ford compressor was bad. Sanden made a replacement for it (which surprised me) and they converted it to 134 while they were in there. $1300 bill ![]() I do most of my own AC work on our cars. I just replaced the compressor on my wifes 2000 SS camaro with a new GM unit, new accum/dryer and orifice tube and the parts alone set me back over $500 alone, I installed everything, then pulled a vacuum for 30 minutes and charged it myself. My time is worth something. Starts to put that $790 more in perspective ![]() Check Rock Auto for factory replacement new GM compressors and get a price, and then check out Sandens website for a replacement. If you convert to 134 and you have a vacuum pump, you can suck it down and charge it yourself and save some coin. |
Napa Auto Parts:
compressor - $274 accumulator - $22 orfice tube - $2.50 freon - roughly $6/$7 each
1977 SWB C10 - "Woodson": 5.3 Vortec LS Swap, 4L60e Trans, 4.5/5 drop |
Make certain that Napa compressor is a brandy new unit and not a reman.
that's brand new prices, just bought one myself
After sending emails & Photo's back and forth with a ebay company I finaly got one New for $205.40 with free shipping. I also been told that you can't reuse the freon in Florida. So I will have to pay another $70.00 for that too, I'm going to install the Compressor myself.
Thanks Guys |
#7 | |
_______________________________________________ 1985 Chevy Scottsdale K20 350 with 700R4 running 3.42 gearing aka "The Honey Badger" 1993 Silverado C3500 Ext. Cab Dually 6.5 turbo diesel |
BAD BOW-Silverado XST
The older compressors can work well. It's all about keeping enough air moving through the condensor!! If you don't have enough air moving, pressure increases fast causing leaks, seal. or compressor failure. Trust me, I've rebuilt mine four times!! I'm on my fifth compressor. I finally know enough to make this last fix last a long time with electric fans. I've also had bad luck using old compressors. I finally found one that looks promising to last a long time. Blowing 60 degree air on 100+ degree days!! YEA!!
#10 | |
Alot of things can cause high pressure, but one of the more frequent causes are converting to 134 while still using a stock R12 condensor that doesn't cool the 134 well enough. As that condensor heats up and that 134 gets warmer, the high side pressures increase. Typcally in this case you can't get as much 134 in the system as needed in an effort to keep things from popping ![]() You are right, electric fans do help to keep the condensor cooler when in slow traffic or sitting still. Any way you can find to keep that condensor cool is a step towards a better working AC system. |
Thanks everyone for your help, I finally got the air working like a fridge. I had to replace the A/C radiator since it was the last thing that was leaking. The only thing that wasn't replaced was the evaporator on this crazy trip. I did find out that the system had ben converted, but whoever did it left so many leaks that I should have bought it as a piece of cheese.
Now I just have to fix the small oil leaks on the motor and that should be it for the drivetrain and I can start on the repaint. |
I had my AC compressor, Orifice tube, and dryer replaced. The compressor was a new Delphi. It cost $1,108.00
#13 |
My total was about $600.00 not counting the other idiots that tried to fix the leak.
