View Poll Results: Did you pull your front clip to install your LSX? | |||
Yes, Pulled it! |
12 | 66.67% |
Nope, didnt need to! |
6 | 33.33% |
Other (problems with either method, etc) |
0 | 0% |
Voters: 18. You may not vote on this poll |
Poll: Pulling the front clip?
I am just about ready to drop the motor in. In all of the swaps I have done on my truck (SBC and BBC) I have never pulled the front clip. I know it can be done either way, but im curious how YOU did it and what issues you ran into.
Always a work in progress
Re: Poll: Pulling the front clip?
I pulled it bc it made it so much easier to drop the LS in and adjust it to where I needed it.
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
It also made routing the wiring for the motor so much easier.
I pulled mine on my S10 knowing I would have to pull and install my 5.3 3- 4 times. Just to get everything right.
![]() Join Date: Jan 2007
Because I installed mine in the street I wanted to be super stealth about it so that the neighbors didn't have a fit.
For the couple days before I undid all the bolts I could. I pulled the rad support, radiator, etc. I left the fenders on (by loosening other bolts). I pretty much had everything lined up and ready to go. Early on Saturday morning I removed the hood and removed the grill that was hanging by a couple of bolts. I had the original motor/tranny out and sitting in the bed of the truck by about 6:30am and everything put away by 7. The neighbors were none the wiser. The rest of that day I spent washing, cleaning and painting the frame. In the evening I mounted up the ECE mounts. Early the next morning I had the 5.3/4l60e installed early and the neighbors were oblivious, also. Certainly, there were some hang ups that happened but having the rad support off help me line up the motor and tranny mounts a lot easier and quicker... I also had the rad support off for the 6.0 install and 8.1 install...but then again they were full project vehicles, also.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
JRods Garage
I plan on taking mine off for my install. However I am installing a dropmember and some other goodies as well
meowMEOWmeowMEOW
Didn't bother pulling mine, just yanked the radiator out to make room. Putting the engine and trans in together was no problem, just requires spending an extra $30 for a load leveler for the engine hoist.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
I'd pull it! Having the front clip out of the way makes it much easier when swapping in an engine that didn't originally come in your truck. If your're absolutely sure your parts are going to work and you'll only have to put it in once then it would definitley be easier to leave the front clip on, but in my experience things never go that smoothly.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
I've seen pictures of the rad support upper crossmember being a removable item....
Well you guys have just about convinced me. Its just another one of those things though... I want to start making progress, not take more of it apart!
![]() Im sure the factory assembly manual will guide me through |
If you are going same for same leave it, there is plenty of room leave it on saves a lot of realignment problems
94 k2500 EXCab Long Bed 350ci New Toy 95 K2500 Suburban New PlowTruck 454ci Support our Troops @ http://anyairman.com http://www.woundedwarriorproject.org/ |
i think it would be worth the effort not that hard anyway as long as you have the extra room
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
#13 |
I would imagine it would make it alot easier, but I only removed the hood on mine, and I still had plenty of room. I just had to be extra careful since all my underhood is paint matched.
