Old 07-23-2012, 08:03 PM   #1
blownz
Active Member
Gas Tank In/Top Off
I spent this past week installing a new gas tank in my K5. I only had short periods of time to work on it. This past Sunday I finished it up. The only thing left is to purchase some more gas vent line. I used a piece of clear to hold me over. Everything works great, so I buffed it up and took the top off. It was worth all the trouble. My neighbors cousin came over and wants to purchase it! I declined.
blownz is offline   Reply With Quote
Old 07-23-2012, 08:26 PM   #2
flashed
Re: Gas Tank In/Top Off
Very nice , I would have declined his offer to buy as well.
flashed is offline   Reply With Quote
Old 07-23-2012, 10:48 PM   #3
Pife
Looks great. Is it all original except the seats?
Pife is offline   Reply With Quote
Old 07-24-2012, 06:25 AM   #4
blownz
Active Member
Yes it is, I have been searching for a pair of the original seats. They are hard to come by around Maryland. It also has a 400 in it. I looked up the numbers and the motor came out of a 72 Caprice. The inside is rhino lined.
Old 07-24-2012, 08:53 AM   #5
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Man, Id drive the wheels off that!
Tom Vogel is offline   Reply With Quote
Old 07-24-2012, 02:37 PM   #6
fear_nothing
fear_nothing's Avatar
A timely post.... where did you get the gas tank? Did you have to lengthen the metal filler spout on the replacement tank?
Great Blazer BTW
fear_nothing is offline   Reply With Quote
Old 07-24-2012, 09:32 PM   #7
blownz
Active Member
I got the tank kit from LMC, best price with shipping. The Truck Shop actually manufacturers the tank, but to ship from Cali was too much. I cut the old curved neck off, shortened the the new filler by an inch and used 1 3/8 id filler hose to make a coupling. That made it easier to move the neck around when installing. I had the tank in and out 3-5 times fitting the straps, changing vent line hoses and being a knucklehead! The last time I installed I forgot to hook up the sending wire. It's all good though.
Old 07-24-2012, 09:37 PM   #8
blap
blap's Avatar
Nice ride.Just pulled my old tank out today.
Looks like a nice clean replacement!
blap is offline   Reply With Quote
Old 07-24-2012, 09:39 PM   #9
blownz
Active Member
Good Luck!
Old 07-25-2012, 03:25 PM   #10
Yukon Jack
Post Whore
Yukon Jack's Avatar
Great looking K5!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-27-2012, 02:22 AM   #11
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Very nice! Just took my top off this week too. Gonna drive it to work a couple of times next week.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 07-30-2012, 09:49 PM   #12
blownz
Active Member
I was out driving the K5 and all the sudden smoke from under the dash! Pulled over unhooked the battery and a orange wire was smoking. I took it loose from the fuse box and freed up a couple of melted wires under the hood and drove home. After further investigation, I found it fried in the fuse box, not bad though. A little more work before I can be back out! I will post pics tomorrow.
Old 08-01-2012, 12:09 PM   #13
red71cheyenne
Back in the sticks
Ya, these old trucks and there old wiring can surprise you. My wife drove my pickup one time and somehow the emergency brake shorted out the whole fusebox and burnt up most of the wiring. I ended up replacing with a Painless fuse box. They are not painless though. Good luck!
2011 K1500 Suburban
2014 K1500 Pickup
Old 08-01-2012, 07:21 PM   #14
blap
blap's Avatar
Do ya have a part # on the hose ,Just need the hose to do my install
Old 08-05-2012, 10:01 PM   #15
blownz
Active Member
blap, I will look on the hose tomorrow and get the part #. I got the wiring fixed and I went to the Truck Nationals @ Carlisle on Friday. I went up to buy some things from guys at the Truck Shop. They have great prices and the quality is very good on there parts. This afternoon I installed the dash pad and alot of small parts on the dash.
Old 08-14-2012, 03:12 AM   #16
jeffneil1964
Question Re: Gas Tank In/Top Off
Is that a factory 20? gallon tank or is it something bigger?
jeffneil1964 is offline   Reply With Quote
Old 08-14-2012, 06:26 AM   #17
blownz
Active Member
It is the 20 gal. It is the same size that I took out.
Old 08-14-2012, 11:55 AM   #18
jeffneil1964
Thanks. BTW nice rig
