07-24-2012, 02:46 AM | #1 |
has anyone put a NV3500 in their truck?
just wondering if anyone has done this swap? curious as to how they got the hydraulic clutch to work and what they did for the speedo, pics or build thread would be great, i had an 88 chev short box lowered with a 5 speed and i drove the you know what off of it, probably the funnest truck i owned and the trans held up too, i miss the truck and would like to make my 72 a 5 speed so if anyone can shed some light on this swap please help, iv already read rays thread and there isnt anything on the swap just info on the transmissions
07-24-2012, 04:24 AM | #2 |
Re: has anyone put a NV3500 in their truck?
This has a lot of helpful info..
http://67-72chevytrucks.com/vboard/s...d.php?t=531009
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
07-24-2012, 05:24 PM | #3 |
thanks again tim
07-24-2012, 06:18 PM | #4 |
The Older Generation
This one too... http://67-72chevytrucks.com/vboard/s...d.php?t=438224 This is what I used for a speedometer. http://67-72chevytrucks.com/vboard/s...d.php?t=421745 LockDoc
07-24-2012, 06:29 PM | #5 |
thanks leon
07-24-2012, 06:36 PM | #6 |
No problem.
Also, don't rule out the Jeep AX15 or the Toyota Supra Turbo R154 5 speeds.(basically the same trans) There is an adapter kit available to bolt them up to the Chevy bellhousings and they are supposed to be a pretty stout manual 5 speed. The adapter is a little pricey but it is milled and the kit comes with a GM bellhousing locator/throwout sleeve and mounting hardware. http://www.novak-adapt.com/catalog/kit_gmax15.htm I bought the kit and I have a Jeep 2WD AX15 trans, All I have to do is figure out what I want to put it in... If you need a bell housing adapter ring get it from here: http://www.dennymac.com/muncie-bell-...g-adapter-ring The Novak one is $32.10 plus $15 shipping and the Dennymac one was $28 shipped when I bought mine. LockDoc
07-24-2012, 06:41 PM | #7 |
yea thats a lil pricey considering i can get the whole truck the trans is in for 100 bucks lol but what yrs did those come in the jeeps?
07-24-2012, 06:51 PM | #8 | |
It tells the years in the article about the adaptor on the Novak site. LockDoc
11-07-2012, 11:10 AM | #9 |
LockDoc have you done the swap yet? I have the trans, gotta get the adapter and figure out the specifics on driveshaft.
11-07-2012, 03:04 PM | #10 | |
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
11-07-2012, 05:26 PM | #11 | ||
LockDoc
11-09-2012, 11:13 AM | #12 | |
11-09-2012, 04:57 PM | #13 | |
I think the pickup version is different but the Toyota Supra Turbo, R154 5 speed is exactly the same... LockDoc
11-09-2012, 05:21 PM | #14 |
I put a Late model (89 i think) SM465 in mine. The hydraulics are almost the same. So I might can help with the hydraulic clutch.
I used the factory master, slave and line all from autozone for the same year as my transmission. Next i used a cut down brake pushrod from our 69 parts truck. The hardest part was getting the hole drilled on the pedal in the right spot so the clutch would fully disengage with minimal effort. The first time i did it it didn't work so good. I had plenty of travel, but it was hard to push. I just redid it and now I got it perfect. I can add pics later and get measurements if anyone needs any.
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
