Building Dreams out of Dimes!
Starting my engine for the very first time. Any tips or suggestions?
Well... After 5 long years it is finally time to start my truck for the first time.
I have a fire extinguisher and my wife has 911 on speed dial. My plans are to prime the carb, fire it up, rev the engine above 1500 rpms for around 15 or 20 minutes. Shut it down. Any other tweaks that you make? Thanks!
1981 Chevy short/wide. SB400 350th Last edited by Hazieview; 07-24-2012 at 09:27 AM. |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Starting my engine for the very first time. Any tips or suggestions?
yeah make sure that you have oil pressure before you try to crank it.. in fact change the oil and filter then crank it without fuel to get the pressure up then put the plugs in and fire away
#3 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
How long should I have to turn the engine over until I see pressure? I have electric gauges for the first time so I'm not fully confident in them yet.
Also is it ok to do this with the plugs in because they are already installed. Thanks! Posted via Mobile Device
1981 Chevy short/wide. SB400 350th |
Dont put your head over the carb if it may possibly backfire and blow your eybrows off haha
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#6 | |
is this a brand new engine?
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
If it is a new engine with a flat tappet cam, make sure and use some break in oil. The oil they sell in the parts stores today doesnt have the zinc and other ingredients to break in the cam. There were a lot of guys losing cams on the break-in around here til we figured this out. Joe Gibbs Racing Oils makes an excellent break-in oil.
This is a bran new rebuilt engine with zddp mixed in with the oil
![]() Posted via Mobile Device
Prime the oil pump.. Bring it on tdc put the dizzy in and fire it up... RPM 2000 for 15 to 20 mins. Some run no water for the first few mins and then add water
BAD BOW-Silverado XST
Borrow a priming tool! Prime it really good using a 1/2" drill. Priming will help oil everything before start up. It can take up to 30 sec for complete oil flow throughout the engine. Priming the carb helps too. You can pour a little fuel down the intake too.
Everyone forgot the most important one RECORD THE VIDEO!
Posted via Mobile Device |
#13 |
exactly....prime the oil pump, dont just pull plugs and turn it over a few times as stated way above
#14 | ||
We were at the track in Atlanta with a new engine; trying to get the Dominator carb baselined. I cranked the engine just as my builder was looking down the carb bores and bumping the accelerator pumps and FOOF it burped and got him. Singed half his beard and one of his eyebrows but he was ok. In rememberance of the occasion he had his helmet painted like this: ![]()
#15 |
Get a good timing light and set it as soon as it' running!!!
Get a big box fan and use it to blow through the radiator. Engines get hotter on their first fire-up than any other time due to the increased friction while parts are getting to know each other. Be aware that it may go over 220* - if it's not much, don't worry about it, it should come right down. Vary the revs from 1500 to 2 grand or so. It will smoke a bit at first, you'll know the rings have seated/sealed when this stops. Once it's broken in for the required 20 minutes or so, change the oil and filter and go beat on it a bit. It takes combustion pressure to really get the rings pushed against the cylinder walls for a good break-in and you ain't gonna get that by ***** footing around. Hit it hard to about 5 grand or so, then dump the throttle and let it coast back down. Do this 3 or 4 times and your rings should be well seated and the smoking should stop. No 6 grand blips until you have a couple of hundred miles on it, it takes several heat/cool cycles to get everything stabilized. Then....HAMMAH DOWN!!! |
#16 |
It was also suggest that I pull the plugs and squirt a little bit of marvels mystery oil on top of the pistons? Anyone against that? I have a pruning tool so I will for sure prime the engine too.
#17 | |
Also, just run distilled water in the radiator etc, no anit-freeze or plain water. This too will need to be drained.
#18 |
When I primed my engine it took a little bit before I saw oil run ooze out of the push rods. Also, I used a garden hose to mist water over the front of the radiator when it got over 220-230 degrees. Just a spritz of water, not enough to drench the radiator. Of course that is in addition to the water that is already circulating inside the radiator.
#19 |
Well the mystery oil is suppose to be better because its a 'fuel side' oil. Better on your spark plugs than just plain oil.
Also, I am running water hose water in the radiator and I have dual electric fans. This will be a goid test to see if they come on too. Anything else? I like all the info! Thanks! Posted via Mobile Device
#20 | |
sounds like you got all the answers......good luck
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB Last edited by 88Jimmy4x4; 07-25-2012 at 09:16 PM. |
