Not too old to learn
Qjet clip info ?
For want of a throttle rod clip I can't fire the new engine.
![]() Ya after the seven years of parts storage I found and identified most things, but not this missing clip to attach throttle rod to carb butterfly cam. Of course local car parts shops can't help, and can't find any pictures to know what to look for. Here is picture of my carb with rod sitting there. Anyone ?
1968 C10 a way to long restoration. |
Re: Qjet clip info ?
I think there is a hole for a cotter pin, don't see a groove for a clip. Also supposed to be a nylon bushing.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
It'll Buff Out!
![]() Join Date: Apr 2007
I'm not sure if this will help, mine is currently with the engine builder but I found these pics on my pc.
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB |
No cotter pin or groove, this must be a very early carb and
I believe would have a clip that looks like a claw.
It'll Buff Out!
72 big block, not sure if that makes a difference.
The Older Generation
You have the rod on backwards. The threaded part goes toward the firewall. The carb end gets a small washer and cotter pin and the firewall end gets one of the clips at the top of this picture. http://www.oreillyauto.com/site/c/de...0286&ppt=C0142 LockDoc
As I recall it is a lot like this Camaro setup. Or they also have a $15.00 "universal' throttle rod if it is a matter of getting it running.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#8 | |
LockDoc
#9 | |
So I switched it and now lines up to allow the clip fit easily. Now I'll find the correct clip. The threaded rod end connector to foot pedal arm is a loose fit no room for a rubber bushing. Thanks.
#10 | |
No problem. Try your local auto parts store. I think my local NAPA store has them. LockDoc
