07-24-2012, 03:01 PM | #1 |
Djm flip kit. Made from top grade modeling clay?
Do I need to say anything? This is one month time on these. At first they didnt fit and I had to weld extensions so they can reach. Now when I pull my ten bolt i find these warping and walking around. I would hate to see what would have happened if i had made it to the track with some sticky tires. Needless to say. The whole kit I got from them is junk. Shock extensions are to wide. The u bolt threads gall way to damn easy even when slathered in anti seize and still on top of it all nothing fits right Please nobody buy this junk! Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
07-24-2012, 03:07 PM | #2 |
Re: Djm flip kit. Made from top grade modeling clay?
Wow that is terrible, one good launch and id hate to see the aftermath with those things.
Posted via Mobile Device |
07-24-2012, 03:14 PM | #3 |
Aftermath would be me going after djm hardcore. Im posting this on every truck site in the web. This crap should not be sold or advertized in anyway. Going to straighten these. Rebar reinforce and case harden them and send them back and tell them to "revise" thier design
07-24-2012, 03:35 PM | #4 |
I always use belltech or western chassis on my stuff, my 3/4 has belltech flip rear and drop spindles and springs front for a 5/7. My dads 96 tahoe has belltech flip rear and drop spindles front for a 3/5. he has used that same set up on all his trucks and it rides great and they are high quality
1969 chevy camaro Z28 #matchin Factory 4wheel disc 1969 chevy cst10 big block overdrive 5/7 drop dog dishs 1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s 2004 gmc sierra dually 4/4 lowering daily driver |
07-24-2012, 03:51 PM | #5 |
Well clearly these kits are dine for driving to the car show. But nothing but issues from mine
07-24-2012, 04:37 PM | #6 |
I had similar problems with the DJM kit I ordered for my truck, brackets were too short.
I sent it back to store were I bought it , I had just struggled with the Adco sway bars I put on and didnīt have the time or patience to deal with it. If I make another attempt to lower the truck I will probably make my own brakets. You are lucky that the old 10-bolt gave in before something worse happend.
Tom.______________________________________ The fleet: 2007 BMW 530xi M (daily driver) 1986 C-10 Stepside (project "my time") 1992 Corvette cab (summer time daily driver) 1969 Cadilac DeVille Cab ("it just need some paint") |
07-24-2012, 05:00 PM | #7 |
I know. And i was about to do some 1/8th mile at monroe which is a circle track and has a hard right at the end
07-24-2012, 06:20 PM | #8 |
At the body shop.
Buy weld on axle pads.
" That didnt make it any newer " " Dont antique the equipment " |
07-24-2012, 06:28 PM | #9 |
Thats my next move. So much easier than flip brackets too
07-24-2012, 07:08 PM | #10 |
07-24-2012, 10:14 PM | #11 |
I hope their spindles aren't that poorly designed....
07-24-2012, 10:36 PM | #12 |
Your scaring me. my whole drop on my 01 is DJM. Guess I will be taking a CLOSE look this weekend!!
07-24-2012, 10:39 PM | #13 |
got these for 12.00 .welded them on no problems here.those flip kits are junk theres only one right way to mount a leaf spring rear.and it doesnt include a peice of flat bar bent into a u.first time i saw those i laughed.
07-24-2012, 11:30 PM | #14 |
I also installed djm 1024 kit on my 1986 10 bolt, The flip bracket installed fairly tight with no slop,I wonder why yours were short ? I definitely will be re thinking my flip..Look's like perches are the way to go...on the the other hand there are guys that swear the djm brackets are the bees knees ...lol..Its worth taking a peek down under to see whats up..nice post...thanks
Common sense is not that common... |
07-25-2012, 12:14 AM | #15 |
Badass
hmmm this scares me.. i have that flip kit on my truck. and im running 13.9 at the track. might have to take a look at mine...
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
07-25-2012, 01:28 AM | #16 |
Devils Advocate Possible u-bolt loose causing this?
1978 C10 Silverado Big 10 350/350.. play toy 1990 V1500 Suburban 350/700r4..Daily driver 1987 K10 Silverado 383/400.. Wife's rig WRECKED! 1989 V2500 Suburban 350/400.. SOLD! 1974 C10 Custom10 LWB 350/350.. SOLD! 1974 C10 Custom10 SWB 350/400.. SOLD! 1999 Silverado Z71 LS1.. Wife's rig WRECKED! On the hunt for a new project....... I'm a Chevy guy.....I'm just not a "NEW" Chevy guy. |
07-25-2012, 01:34 AM | #17 |
For the money. A leaf perch is better and stronger than the speghetti bracket djm gives you and thier poor excuse of u bolts and shock hangars.
Im sure part of the prob is my trans chirps the tires when going through gears. Even then BOTH sides bent Which means its not just the shifting. Im going to call djm again and see what they have to say. Im betting you they are going to say these brackets are not good for any racing and no good for higher power engines Posted via Mobile Device
07-25-2012, 01:36 AM | #18 |
No torqued per spec driven an hour and half to let things settle and then re torqued
07-25-2012, 01:37 AM | #19 |
no good
07-25-2012, 02:32 AM | #20 | |
07-25-2012, 03:28 AM | #21 |
hmm you have me worried.
my truck has had a DJM flip kit on the rear for like 8 or so years as well as all DJM front lowering kit 4/6. though my truck rides like a caddy with it all and ive never had a problem, i think i might take a look tomorrow. eep!
1969 Shortbed in progress 1982 short step, few suspension and motor upgrades.getting a 468 1978 Shortbed fleet side bonanza fully loaded 1978 k20 Silverado loaded.currently engine-less 1989 k10 suburban 9" lift 65 nova And more |
07-25-2012, 06:24 AM | #22 |
Old Heap Driver
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
07-25-2012, 06:32 AM | #23 |
67-72 parts collector,
The problem with the weld on perch,... is that, they don't relocate the rearend back approximately 1" like the flip kits do.
This helps center the rear wheels in the wheel opening and keeps the driveshaft from bottoming out after the rearend in flipped on top of the leaf springs. They also correct the pinion angle. I've used Belltech flip kits on 73-87 trucks forever,... without any issues. Western Chassis makes a very nice product also.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 07-25-2012 at 07:50 AM. |
07-25-2012, 07:37 AM | #24 |
Welded on perches and factory spring plates can be drilled for a second hole to move the rear end back. You can drill the old perch to install some fine tuning bolts to fine the pinion angle too. I used a cheap trailer axle perch to do this one but a new real perch is in the works. If you will also notice the Ubolts should be 9/16". Several aftermarket lowering kits have 1/2" Ubolts. Back in the late 70s and 80s the metal was just starting to get poor. Now it's terrible. The metal used was likely not hardened steel.
Keep in mind your Ubolts need to be torqued evenly simular to a cylinder head. |
07-25-2012, 10:03 AM | #25 |
I have a DJM flip also. I noticed the U bracket was short and didnt fit right. I couldnt return them so I got another pair of BellTech brackets and used them. I saw how many people were using DJM stuff and figured alot of people must be installing them and not realizing how bad they fit.They are now in my scap pile of extra metal.
Tags |
djm flip kit review |
